Integra Antenna Plug
I finally gave up trying to find a genuine honda antenna delete plug, i must have tried at least 10 different plugs from firewalls of various cars and boats in the last few months, but today i finally found one that is a near perfect fit and seals the hole extremely well. At first it looked a little too big and i managed to get approx 3/4 of it into the hole but using a small flat head screw driver i was able to gentle coax the remaining part in. I then stood with a garden hose blasting around the plug to check for leaks and thankfully there are none and its a perfect seal.
Modified by mugenracer at 2:59 PM 5/28/2006
The one i got is 25mm and a dead tight fit, but if you could find 23mm then it'll be perfect but you may need to use sealer or glue to get it to seal properly.
If anyone wants one then i have put the rest of them on ebay, item #8070162748
I was wondering if it's the same size for the DA. My antenna is stuck in the up position. I had the head unit replaced, and now it doesn't work, and I got sat radio now, so I no longer need the antenna. I'm just tired of looking at the almost CB sized antenna sticking up. I'll go get the 23mm, and 25mm, and see what happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC »</TD></TR><TR><TD CLASS="quote">I was wondering if it's the same size for the DA. My antenna is stuck in the up position. I had the head unit replaced, and now it doesn't work, and I got sat radio now, so I no longer need the antenna. I'm just tired of looking at the almost CB sized antenna sticking up. I'll go get the 23mm, and 25mm, and see what happens. </TD></TR></TABLE>
let me know which one works
sounds like somebody just didn't hook up the power antenna plug.. i wired my alpine stereo, and the power antenna works great... you should check that before getting rid of it altogether
I have shipped out the plugs to everyone that has paid so far. The guys in the post office have been asking me what the hell i'm sending out as i have been everyday this week sending out 3 or 4 at a time, but if i told them...i'd have to kill them!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingKenny »</TD></TR><TR><TD CLASS="quote">great job on this so do you also take the antenna motor out or just the antenna itself and plug that rubber in?</TD></TR></TABLE>
You need to remove the whole antenna to fit it. I never listen to the radio anymore so didnt see any point in having an antenna anymore, but had to wait till i found a plug that fitted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecfool »</TD></TR><TR><TD CLASS="quote">thanks for telling us the size
, no more broken boner antenna
no more radio frequency! mine doesn't even go up. unlike yours that is always up justin. hahahaha
</TD></TR></TABLE>no more radio frequency! mine doesn't even go up. unlike yours that is always up justin. hahahaha
