Problem with new brake pads
Old May 28, 2006 | 11:05 AM
vinuneuro's Avatar
Default Problem with new brake pads
I'm in the process of installing the rear pads on my Prelude, but the pads didn't come with new shims. Here's the bad part: the pad backing on the new one is a little taller than the pad backing on there now (few mm), so the shims don't fit properly. It's the right part for my car. What am I supposed to do now?
Old May 28, 2006 | 11:10 AM
Hawkze_2.3's Avatar
Default Re: Problem with new brake pads (vinuneuro)
Push the piston in further....or leave the shims out if you can't.
Old May 28, 2006 | 11:20 AM
vinuneuro's Avatar
Default Re: Problem with new brake pads (Hawkze_2.3)
No, i mean the little tabs over the top and bottom of the shims won't fit over the edge of the new pads.
Old May 28, 2006 | 11:24 AM
InvaderTrax's Avatar
Then don't use the shims. Only risk you run is squealing
Old May 28, 2006 | 11:26 AM
vinuneuro's Avatar
Default Re: (InvaderTrax)
Can I still apply grease to the back of the pad backing?
Old May 28, 2006 | 12:28 PM
vinuneuro's Avatar
Default Re: (vinuneuro)
bump
Aphelion
Apr 23, 2005 09:20 AM
mingbling96
Dec 21, 2004 02:39 PM
eXcelonTypeR
Nov 5, 2004 05:42 AM
Floyd
Feb 20, 2002 08:25 AM
blkbeast
Jan 14, 2002 12:58 PM
