?? question about cutting crossmember to fit downpipe on a ef ??
Old May 28, 2006 | 10:07 AM
superhatchbackbros's Avatar
Default ?? question about cutting crossmember to fit downpipe on a ef ??
im currently fitting up my turbo on my ef and i ran into the crossmember problem. the downpipe almost fits but needs just a lil modz to make it fit. i heard u can grind it or cut it out a lil and it works? im on a low budget so i cant afford an aftermarket one.. so for now i need to grind it out? does anyone have and easier way to cut it out or just keep grinding. and do it the best i can? can someone please give me some feed back asap so i can get this project on its way? bc after that i should be good bc i have all my peices i need to get it up and ruining.. thanks in advnaced.......
Old May 28, 2006 | 10:37 AM
thevtecnician's Avatar
Default Re: ?? question about cutting crossmember to fit downpipe on a ef ?? (superhatchbackbros)
Just turn the grinder sideways and use as a cutter. I had to grind mine down but I just had a lsvtec motor.
Old May 28, 2006 | 10:51 AM
Hankish's Avatar
yeah, I just cut some out to make my JDm R header fit in my DA. it will be ok. There are some nice traction bars out there but they are allll $$$$!
Hank
Old May 28, 2006 | 11:00 AM
thanks guys... so far i took the crossmember off and im grinding it ever soo nicley lol.. and im going to do it outta the car... ill see what happens... thanks
Old Aug 7, 2007 | 10:33 AM
SiR Inspired ED7's Avatar
I ran into this trouble, Im debating wether cutting it or not. Wont handling be affected? I want to buy a hytech header or just a 4-1 type r header but, Im worried that handling will be affected. What has been your experiences for those who have cut their cross member to fit a header.
Old Aug 7, 2007 | 10:51 AM
powerpro_69's Avatar
Default Re: ?? question about cutting crossmember to fit downpipe on a ef ?? (SiR Inspired ED7)
just get an aftermarket crossmember
Old Aug 7, 2007 | 10:53 AM
STREETWERKZ's Avatar
Default Re: ?? question about cutting crossmember to fit downpipe on a ef ?? (powerpro_69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerpro_69 &raquo;</TD></TR><TR><TD CLASS="quote">just get an aftermarket crossmember</TD></TR></TABLE>
srsly.
Old Aug 7, 2007 | 11:04 AM
APEX CRX's Avatar
save cash then buy one
Old Aug 7, 2007 | 11:08 AM
Pee Wee's Avatar
Default Re: ?? question about cutting crossmember to fit downpipe on a ef ?? (APEX CRX)
srsly. </TD></TR></TABLE>
^truth^
why hack up such a vital part when aftermarket bars can be had for pretty cheap now
Old Aug 7, 2007 | 02:26 PM
Default Re: ?? question about cutting crossmember to fit downpipe on a ef ?? (Pee Wee)
witch after market crossmember clears the hytech header because i'v read that some after market crossmembers don't clear some race headers
Old Aug 7, 2007 | 04:54 PM
welfarepc's Avatar
aftermarket traction bars arnt cheap, OP is broke. doesnt add up. cutting the stock x member is just as bad. why not get a DP that fits?
Old Aug 7, 2007 | 07:11 PM
Default Re: (welfarepc)
this is what i have
http://www.innovativemounts.co...59111
Old Aug 7, 2007 | 07:32 PM
Tippyman's Avatar
Default Re: (powerpro_69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerpro_69 &raquo;</TD></TR><TR><TD CLASS="quote">this is what i have
http://www.innovativemounts.co...59111 </TD></TR></TABLE>
I bought mine for $180 shipped. Brand new.
Innovative mounts x-members go used for dirt cheap all day long.
Old Aug 7, 2007 | 08:19 PM
same ol Steve's Avatar
if it only needs a little removed just use a big f'ing hammer to dent it out of the way but carefully of course trial fit it often
GabesEF909
Apr 12, 2012 07:51 PM
zerobytegeek
Feb 26, 2009 08:23 PM
kwint
Suspension & Brakes
Dec 22, 2006 10:02 AM
Demon_Dub
Nov 25, 2005 09:53 AM
TURBO B
Aug 14, 2003 10:51 PM
