can i use the B20 crank pulley on my JDM B20 swap into 91 integ?
i recently bought a 91 integra and i'm not sure if they guy swapped over the LS crank pulley or not. is it possible to use the b20 crank pulley when you swap in the motor cause i've heard you have to use the old LS crank pulley? will the B20 crank pully match with the integra alternator?
it is different type of grove for the belts.
so no..
unless you are planning to change all the pulleys.
so no..
element1791
Jan 28, 2015 05:14 PM
