where to get a good clean RPM signal for WBO2
Old May 28, 2006 | 08:33 AM
CoreyR's Avatar
Default where to get a good clean RPM signal for WBO2
i tried searching but all i found was "blue wire behind cluster" well that signal sucks ***** and wont work properly on my zeitronix. id prefer to tap it right off the ECU if possible.
Old May 28, 2006 | 08:43 AM
crxnj's Avatar
Default Re: where to get a good clean RPM signal for WBO2 (CoreyR)
the blue wire behind the cluster worked good for my autometer,,dont know why its not working with your setup..but the rpm signal from the (obd0) ecu is B15,,its a white wire..
Old May 28, 2006 | 08:47 AM
CoreyR's Avatar
the signal gets all scrambled when i datalog and also the cluster is reading all fucked up now. like it only reads half of what its really revving to.
Old May 28, 2006 | 08:49 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">the signal gets all scrambled when i datalog and also the cluster is reading all fucked up now. like it only reads half of what its really revving to.</TD></TR></TABLE>
that means there is another problem...probably something distributor related,,maybe ignitor.
Old May 28, 2006 | 08:59 AM
CoreyR's Avatar
Default Re: where to get a good clean RPM signal for WBO2 (Mr.speaker)
it wasnt doing it until i hooked it up to my cluster harness. plus it s a brand new dizzy. had to replace the old one becuase the CPS went bad.
Yuta
Jan 4, 2017 10:33 AM
vtechjunkie
28
Mar 16, 2010 11:14 AM
SHG_EasyE
May 5, 2007 05:35 PM
Adern
10
Feb 3, 2006 08:54 PM
onesikcivic
Jul 5, 2005 08:19 AM
