b20
i just bought a b20 vtec, it came out of a 92 ls, the tranny that it came with is a cable tranny...
my questions are
1-- can i use the same clutch from the cable tranny if i put a hydro tranny?
2-- can i use same axles from the cable tranny in the hydro tranny
3-- do i need to replace the shift linkage or can i use the same one??
thanxs.......
my questions are
thanxs.......
1. yeah,,if the clutch is for 92+ tranny..90-91 clutch is different..
2.yeah,,as long as you keep the cable halfshaft ,,and for passenger side axle you may need a different axle seal though when using cable axle on hydro tranny..not completely sure,,but thats how it is when using hydro axle on cable tranny..
3.if the linkage is the from the 92 integra then you need to cut and reweld it,,or buy a premade piece for this swap..
Walterronny
May 27, 2006 04:12 PM
