TICKING From Front End After Tranny Install - Relative To Wheel Speed
Old May 28, 2006 | 05:31 AM
PINKS's Avatar
I want a CRX tattoed on my butt
Default TICKING From Front End After Tranny Install - Relative To Wheel Speed
I blew my tranny this week, took me a good 6 hours to get it installed by myself which sucked, went out for a test drive yesterday and there is an audible ticking coming from what I believe to be my drivers side wheel
Its definetely gets faster and slower depending on speed, but it sounds like it would be the equivalent to one click per rotation of the tire
The car was not making this noise when I took the trans out
Things I installed/changed
-drivers side axle boot clamp was loose and was slightly leaking grease, I cut it, shoved a little wheel bearing grease in there and clamped it with a high quality stainless hose clamp TIGHT
-drivers side axle didnt have a c-clip on the tranny side, I added one
Thats all that was changed
Need some help
Thanks guys
Old May 28, 2006 | 06:38 AM
philkehn's Avatar
I would say check your cvs' that would be my first guess, do you have all your bolts on your tire would be my second, and if not the only other thing it could be is a look bolt, when you were putting back together.. I would say if these dont take car of it its probably internal
Old May 28, 2006 | 06:52 AM
EF_ST@TUS's Avatar
axle..../wheel bearing
Old May 28, 2006 | 08:52 AM
PINKS's Avatar
Default Re: (Lost_in_a_world_so_cold)
Im thinking its the hose clamp posibly
Does the end of the axle boot come extremely close to anything?
Old May 28, 2006 | 10:32 AM
philkehn's Avatar
it shouldnt, you should see the boots from the top of the engine bay.. did you put the cvs' in your self?
Old May 28, 2006 | 11:13 AM
nappyroots827's Avatar
Default Re: (philkehn)
dude, mine is doing the same damn thing, i just replaced my driverside axle and i have a ticking noise coming from the driverside wheel, and it only seems to do it when im going straight or turning right....it almost seems to go away after driving a long time for some reason
eye.ha8.u
15
Jul 3, 2006 08:08 PM
PINKS
May 28, 2006 08:53 AM
SpoonFedHatch
Sep 20, 2004 05:48 PM
SpoonFedHatch
Aug 4, 2004 09:08 PM
SteelCityKid
Aug 11, 2001 07:33 PM
