[FS:] NSX BRAKE CALIPERS in ohio
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sihb »</TD></TR><TR><TD CLASS="quote">Nice calipers what year are they from?And does is come with the rotors ? what size rim 15 or 16 ?***Bump*** </TD></TR></TABLE>
these dont' come with the rotors, and I was using them on a 16" slip... and I would have to guess they are from a newer nsx.
i've seen them go for around $400 used, so im hoping somewhere in that ballpark
will try to return everyone's pm
you do realize you were only using up half of the brake pad how you had them setup? with that caliper bracket they need the 12" nsx rotors because they are spaced out farther.. so you must have had some really uneven pad wear.. with only an 11" rotor.
MiraiZ
Oct 22, 2010 06:32 AM
