rear sway bar mounting points?
Old Apr 13, 2002 | 07:01 PM
02WRX's Avatar
Default rear sway bar mounting points?
umm, search sucks.
that being said, where does the rear sway bar mount up to? somewhere on the trailing arm? or ?
i'm just wondering if having teg trailing arms will give me the mounting points to do a rear sway bar...
tia
Eric
Old Apr 15, 2002 | 11:24 AM
02WRX's Avatar
Default Re: rear sway bar mounting points? (90CivicEX)
ttt -
no one knows where rear sway bars mount up to????
Eric
Old Apr 15, 2002 | 11:28 AM
wronghand's Avatar
It actually attaches to the lower control arms. If you used the lca's from the teg then you will have them. It will also require some custom brackets to mount the swaybar to the frame.
Old Apr 15, 2002 | 11:39 AM
JohnnyM's Avatar
The 4th Gen SI has mounting holes in the LCA. If you have a dx,cx they do not. You can swap in the Si LCA with little effort. The teg LCA are different and will change the suspension geometry. Go with the SI ones....
Old Apr 15, 2002 | 12:39 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: rear sway bar mounting points? (wronghand)
on my old DX hatchback i used si lower control arms, CRX's mounting bracket to mount the bar to the frame, and an integra sway bar. mounts in front of those three bolted towhooks. my DX already had the holes there and threaded. you don't need custom brackets at all.
BUT my DX sedan on the other hand has the holes...but aren't threaded.
Old Apr 15, 2002 | 02:30 PM
wronghand's Avatar
Default Re: rear sway bar mounting points? (HoMoCo FoLife)
I think that some of them got the bolts welded on but most didn't. My CRX DX had wholes but no bolts so I had some brackets made to mount it to the tow hooks.
H22Stew
Suspension & Brakes
Mar 29, 2008 01:33 AM
JMelt4
18
Apr 30, 2007 07:43 PM
crxsleeper210
Suspension & Brakes
May 4, 2006 01:27 PM
EJ1 wilcox
Nov 16, 2005 02:59 PM
Kilohead36
11
Apr 1, 2003 01:54 PM
