bitch pin (shift linkage pin)
Old May 27, 2006 | 09:56 AM
GsrTurboCRX88's Avatar
Default bitch pin (shift linkage pin)
Does anybody have a trick to tak out the shift linkage pin. I know how to do it I just endu up working on it way longer than I should
Old May 27, 2006 | 10:03 AM
EF Two's Avatar
Default Re: bitch pin (GsrTurboCRX88)
Use a punch.
Old May 27, 2006 | 10:49 AM
e jay one's Avatar
Default Re: bitch pin (EF Two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF Two &raquo;</TD></TR><TR><TD CLASS="quote">Use a punch.</TD></TR></TABLE>
and a big hammer. theres a reason its called the bitch pin. the higher the car is the better swing you can get.
Old May 27, 2006 | 11:02 AM
HiProfile's Avatar
Default Re: bitch pin (e jay one)
A punch tends to add to the pin's resistance to move. Get a cheap punch, grind a collar into it to fit inside the pin, then give it a few whacks.
Old May 27, 2006 | 11:07 AM
Masta's Avatar
I use a piece of round bar that's a hair smaller in diameter that is approx. 4 ft. long and give 2 shots from the top. Hasn't failed me yet in 8+ swaps.
You may want to support the shift linkage while hitting it.
Old May 27, 2006 | 11:42 PM
Default Re: (Masta)
thanks guys
Old May 28, 2006 | 12:35 AM
Nisif's Avatar
Use an a/c compressor-to-block bolt as a punch. Works everytime, it's tapered at the end, I can usually get the "bitch pin" out within 2-3 minutes using it.
Old May 28, 2006 | 04:22 AM
downest's Avatar
Default Re: bitch pin (Nisif)
Take the tranny out with the linkage, then take the pin out, it's a lot easier. It's not hard to pull the tranny with the rod, just hard to get it back in.
Old May 28, 2006 | 04:25 AM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nisif &raquo;</TD></TR><TR><TD CLASS="quote">Use an a/c compressor-to-block bolt as a punch. Works everytime, it's tapered at the end, I can usually get the "bitch pin" out within 2-3 minutes using it. </TD></TR></TABLE>
Best damb tool period! I find that bolt works better than any punch.
Old May 28, 2006 | 04:48 AM
10MinSi's Avatar
Default Re: bitch pin (Boosted Chemist)
if you cant punch it out you can always drill it out and get a larger pin at AUTOZONE or HomeDepo
Old May 28, 2006 | 06:29 AM
philkehn's Avatar
I just took my out about a week ago, i took a 10mm bolt out the engine bay, a hammer, and it popped out on about my 2nd good swing
Old May 28, 2006 | 06:32 AM
fireant's Avatar
Default Re: (philkehn)
How I got it:
_use a punch
_get the car high enough for a good swing
_do it while the car is "warm"
I like the A/C bolt idea, I think I'll try that some time.
Old May 28, 2006 | 09:26 AM
Tippyman's Avatar
Default Re: bitch pin (downest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">Take the tranny out with the linkage, then take the pin out, it's a lot easier. It's not hard to pull the tranny with the rod, just hard to get it back in.</TD></TR></TABLE>
That's what I did when I did my swap. Just undo it from the shifter. (two bolts)
it's much easier. Just gotta watch out for the x-member.
Old May 28, 2006 | 09:33 AM
pandarex's Avatar
Default Re: bitch pin (Tippyman)
i hate that pin and everything it stands for, before i knew anything about hondas that pin took me about two hours
Old May 28, 2006 | 09:44 AM
B16-CRX's Avatar
Just replaced my shift linkage at 12:00 last nite and that pin drove me nuts. BTW, all i used was a small punch and a hammer.
Old May 28, 2006 | 09:56 AM
civicwagonman's Avatar
I always use a 1/4 inch bolt.
Old May 28, 2006 | 10:25 AM
Voodooboy520's Avatar
Took me 2 swings to get it out with a 8mm punch.
Old May 28, 2006 | 11:19 AM
silentdork818's Avatar
^^^Thats the tool to use!
Old May 28, 2006 | 01:20 PM
snowseeker's Avatar
Default Re: bitch pin (silentdork818)
I don't understand how everyone has so much trouble with this pin? I have used a punch and hammer for years on many many many hondas and NEVER had a problem yet.
Old May 28, 2006 | 03:41 PM
Default Re: bitch pin (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">I don't understand how everyone has so much trouble with this pin? I have used a punch and hammer for years on many many many hondas and NEVER had a problem yet.</TD></TR></TABLE>
Do you use a lift? the extra swinging room makes the world of difference.
Old May 28, 2006 | 05:13 PM
d357r0y's Avatar
Go to Sears and get a "roll pin punch".
Then you can easily tap it out now that you have the correct tool.
Old May 28, 2006 | 05:20 PM
superacecardriver's Avatar
Default Re: bitch pin (d357r0y)
8 mm pin punch. Get that and a hammer. Easy. Why is it called a bitch pin? :lol: Its actually a roll pin.
Old May 28, 2006 | 05:28 PM
snowseeker's Avatar
Do you use a lift? the extra swinging room makes the world of difference. </TD></TR></TABLE>
Nope, not yet anyhow. Just jack up the car a bit further and put some muscle into it.
Old May 30, 2006 | 10:17 AM
thanks for all the help. i tried the ac compressor bolt and it tool less than a minute! i was amazed
Old May 30, 2006 | 07:14 PM
Nisif's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrTurboCRX88 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the help. i tried the ac compressor bolt and it tool less than a minute! i was amazed</TD></TR></TABLE>
Like I said works everytime, and it's better than wasting money on a punch
Johnoolo
Oct 1, 2013 07:30 PM
Mugencrxsir1
12
Jul 6, 2010 04:58 PM
rjc89sir
Sep 17, 2007 02:15 AM
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
Mr Synister
Oct 18, 2004 11:06 AM
