Help with Turn signal
Old May 26, 2006 | 04:39 PM
nyrican23's Avatar
Default Help with Turn signal
I got a 99 ex and the bulb works fine but just doesnt flashes when i make a turn. This is a brand new bulb also. Is it something in the fuse box?
Old May 26, 2006 | 04:50 PM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Default Re: Help with Turn signal (nyrican23)
Always check the fuses first!
Old May 26, 2006 | 04:53 PM
AntF's Avatar
Well...did you check your fuses? There's also an item connected to the fuse box which makes the blinkers...blink. I wish I knew what the name was. But you should check if you've blown a fuse since it's so easily done.
Old May 26, 2006 | 05:17 PM
tatmark1's Avatar
flasher
turbodelsolb16a2
Aug 19, 2008 06:41 PM
BEAUTYKing
Jun 3, 2007 02:02 PM
wu4607
May 23, 2006 06:57 PM
deetz84
16
May 30, 2005 06:49 PM
GSlowR
12
Oct 5, 2002 07:14 PM
