Clutch for turbo
Old May 26, 2006 | 04:01 PM
tcontesh's Avatar
Default Clutch for turbo
My oem clutch has finally had enough and is slipping, as soon as I get some opinions I am ordering a clutch, my price range is around 350$. do you guys know if centerforce is any good?
Old May 26, 2006 | 04:53 PM
98vtec's Avatar
moderator emeritus
Default Re: Clutch for turbo (tcontesh)
they're ok. I really like the exedy clutches. i'd go with a puck clutch.
Old May 26, 2006 | 05:13 PM
PRELUDE-GT35R's Avatar
Clutch Master STAGE 3
Old May 26, 2006 | 05:33 PM
tcontesh's Avatar
I was actually looking into an exedy clutch but I dont know which one to get for my setup. I am going to be running 8-9 psi as soon as I install the clutch. any suggestions?
Old May 26, 2006 | 05:37 PM
98vtec's Avatar
moderator emeritus
when choosing a clutch you have to look at the amount of torque you are a looking to make for the maximum amount of psi you plan on running. If you go to the actual manufacture site, they should have a guide to choose which clutch for x amount of torque. But i could be wrong, would be smart of them tho.
Old May 26, 2006 | 05:44 PM
tcontesh's Avatar
Default Re: Clutch for turbo (98vtec)
Ok will do but do you know if the centerforce clutch is anygood cause summit racing has them for 5th gens. for like 300 bucks with 90% better holding than stock. should i even bother
Old Jun 1, 2006 | 10:11 AM
94preludeguy's Avatar
I think Stage 1 is rated up to 210hp. Stage 2 290hp. Stage 3 350hp. Not sure but it's a close estimate.
You're probably making 260ish crank am I correct? If you plan on upgrading further get a stage 3. But if you're done then just grab a stage 2. Centerforce is good stuff too.
Old Jun 1, 2006 | 03:08 PM
silentvoice19's Avatar
Default Re: (94preludeguy)
go to horsepowerfreaks.com and theres a company called south bend clutches i like 20 mins from them and they make a really good performance clutch for cheap for 350 you could problly get a really good one.
Old Jun 1, 2006 | 04:08 PM
Rocket Man's Avatar
Default Re: (silentvoice19)
I can vouch for ACT XTREME pressure plate and Street/Strip orangic clutch using it on my 1993 honda-prelude boosting 14# it would grab really nice its kinda of stiff but once u get used to it I couldnt even tell. It wasn't over abusive or rough so it was still very streetable, as where if you buy a racing clutch( Puck's mainly) you might have a issue as alot of them are on/off deals no slipping unless you want to wear it out real fast. I wish I could remember who I sold my used one too, as im sure he can vouch for how good it is. Unfortunately his email has been deleted, but i can remember one of his comments, "Man this thing really grabs."
Old Jun 1, 2006 | 04:26 PM
akstunt600's Avatar
exedy all the way
Old Jun 1, 2006 | 05:06 PM
tcontesh's Avatar
Default Re: (akstunt600)
what about clutchmasters? Stage one organic is only 330 with everything included
Freemananana
Transmission & Drivetrain
Jul 7, 2014 08:33 AM
danmej1
Oct 28, 2009 10:19 PM
honda for life
May 20, 2006 10:57 PM
taffetawhitegsr
Aug 24, 2004 06:16 PM
slowj
Jan 18, 2004 06:25 AM
