Seat squeaks, getting annoying....
lately my seat has been squeaking more than usual,
on the freeway, with every bump it squeaks,
the exact part is where the seat belt clip/holder, is it loose?
i couldn't find anything on this issue...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondageek »</TD></TR><TR><TD CLASS="quote">check the bolts holding it down.</TD></TR></TABLE>
mine does the same thing, it's not the bolt.
it feels like the back support part have alot of freeplay.
the back of the seat might be rubbing against the back plastic. Depending on how you have your seat positioned this might be what's making the noise...hope that helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk »</TD></TR><TR><TD CLASS="quote">check the oil .. maybe its low .. or might as well do an oil change
how heavy are you? .. its could be the spring</TD></TR></TABLE>
you think my seat oil is low?
i weight 155ish i doubt thats it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 »</TD></TR><TR><TD CLASS="quote">the back of the seat might be rubbing against the back plastic. Depending on how you have your seat positioned this might be what's making the noise...hope that helps</TD></TR></TABLE>
the seat isn't hitting the back, i dont drive gangster lol...
i wonder if the remedy is a spoon or bride seat...humm...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 »</TD></TR><TR><TD CLASS="quote"> I like to sit straight up with the seat all the way back...</TD></TR></TABLE>
btw, ^^^ thats waayyy better than the hammer
my did the same it could by how far ur seating back.....is ur seat head part touching the back stock roll bar...if it is it could be that like mine is was...just adjust and move the seat slightly up....mine went away and im still comfy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 »</TD></TR><TR><TD CLASS="quote">don't be jealous my legs reach the pedals
jealous with you white skinny long *** legs? NO
.. very un-proportion with your body rofl
</TD></TR></TABLE>jealous with you white skinny long *** legs? NO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KJ55 »</TD></TR><TR><TD CLASS="quote">Deal with it!</TD></TR></TABLE>
okay..moving back to the topic
-it's not the seatbelt, i notice the passenger side clip will hit the door panel and make all types of noise if the silver part is point toward outside. but again, my gf would be beaten if she left it that way on her way out.
-it's not the seat that come into contact with the back interior panel, although i do have a small amp and two 5.25inch speaker in the rear, but they are not touching.
in conclusion, the seat just squeaks, i guess it's another reason for that sparco/momo huh?
i got a piece of rubber, kinda what you use to insulate windows, doors, etc. found at home depo
i cut a small 2in piece and placed it underneath the clip between the leather and now its perfect, and you can't see the rubber piece anyways.
01celica_gts
Jan 17, 2017 12:31 AM
