2 b16a1 q's
Anyone know if the throttle cable bracket for the y1 can be sourced off any of our usdm tranny's (90-93 LS?)? Also, do I need the front mount (on the front crossmember)?. I'm using the HASport kit and it looks like there's no way for that to happen. I figuring it's not used, but is that why the other mount kits have four mounts?
Do you mean the clutch cable??? or the throttle cable??
And the Hasport mount kit does not use a front mount. I have been running mine for about 2 months now without the front and it is fine
your stock one should work. I used the stock one that was on my car. You could always get a 90-91 integra LS cable. However, I have heard it is the same length as the stock one.
[IMG]C:/my documents/rick/clutch_cable.jpg[/IMG]
I need the bracket that is on the trans that the clutch cable goes through that allows adjusting of the clutch (i think). I dont know if that pic will work, I have no way of hosting it, but if it shows, I circled where it bolts to.
rewerbcrx
Jan 17, 2006 09:56 AM
90civichbsi
12
Sep 9, 2002 06:41 PM
13secondcivic
Feb 17, 2002 06:38 PM
I would get one off of a 90-91 integra.
