Diffences between rsx and crv k swap
Old May 26, 2006 | 06:41 AM
Juniorhatch's Avatar
Default Diffences between rsx and crv k swap
I own a RSX typeS and was looking to swap the RSX block and have a CRV block installed.I also got a jackson charger for the set up.Is it worth the head ache to swap out the RSX block for the CRV?And if the CRV is best to the swap what all would have to be done to do the swap?Any input will be appricated.
Old May 26, 2006 | 07:15 AM
Kal's Avatar
Kal
Default Re: Diffences between rsx and crv k swap (Juniorhatch)
Not really unless you have the time and ability to do so. You would be loosing the oil squirters intergrated into the a2 block for long term upper RPM VTEC running, but you would gain the extra .4L displacement from the k24. If you are deadset on a k24 swap then get a k24a2 (tsx motor). But overall, the a2 is a strong motor for the jrsc.
k20rex
29
Mar 5, 2014 12:30 AM
H2nr
13
Jul 25, 2004 05:58 PM
gsrfrancisco
Jul 15, 2004 05:19 AM
