my timing belt snap ?
so i was driving home @ 65-70 mph right... all of a sudden when i gas it, my car seems to not accelerate but slow down? i thought i was pressing upon the brakes but i WAS on the gas pedal. so i drive normally again for a mile and this time i press the gas again and it slows again but my car complete slows itself down to a stop on the freeway...
i open my valve cover and my timing belt is perfectly fine. no play, i didn't want to try to pull it to hard but the belt looks/feels completely fine. not ruling it out though.
i go to start it and nothing. i tried listening for fuel but it was noisey as hell.
was it because of:
1. no spark/ignition
2. no fuel
3. the timing belt snapped
somebody...anybody. thanks...
was it because of:
2. no fuel
start with the basics..
Check for spark.. if there is no spark then check
1. plugs for fouling
2. Ignition wires
3. ICM
4. Ignition Coil
If u dont hear the fuel pump priming check
1. Main relay
2. Fuel pump
3. Fuel Filter
2. Ignition wires
3. ICM
4. Ignition Coil
1. Main relay
2. Fuel pump
3. Fuel Filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord »</TD></TR><TR><TD CLASS="quote">sounds like a distributor or fuel related problem. If you snapped your timing belt you would most definate notice it by removing the VC.</TD></TR></TABLE>
yeah... my belt is like secure... i hope i didn't stretch the thing by trying to pull it. haha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baPES »</TD></TR><TR><TD CLASS="quote">something like this happened to mine my distributor cap was cracked</TD></TR></TABLE>
it's actually been cracked for a while... still worked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">start with the basics..
2. Ignition wires
3. ICM
4. Ignition Coil
1. Main relay
2. Fuel pump
3. Fuel Filter
i'm leaning towards my fuel... i cannot hear it prime anymore. i changed my filter and my relay is less than a year old. my pump on the other hand is from 94.
anyway, has my engine been damaged in any way internally from this happening?
2. Ignition wires
3. ICM
4. Ignition Coil
1. Main relay
2. Fuel pump
3. Fuel Filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Ive had brand new main relays fail within 6 months of replacement</TD></TR></TABLE>
how do i know if it's my relay or my pump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the soL that could »</TD></TR><TR><TD CLASS="quote">
it's actually been cracked for a while... still worked</TD></TR></TABLE>
Yea same thing for me mine was craked then one day stoped working try to replace its less then 20$
bouncing87souls
Dec 22, 2010 09:04 PM
