ever broke your upper control arm mounting bolts?
Old May 25, 2006 | 09:53 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default ever broke your upper control arm mounting bolts?
as some of you guys know.. the upper controll arms on EF's and EG's.. use 2 bolts through the controll arm, and have a nut tack welded behind the body and that bolts the inner arm.
well, a few of us have broke those tack welds loose.. and in my case, i couldn't loosen all the way out, or tighten it up.. i ended up tourching the bolt off.
well.. i'll introduce a "nutsert".
more pics avail in my listing here..
http://builtb16a.com/random/nutserts
a wonderfull tool to have!
Old May 26, 2006 | 02:28 AM
mrtoastyjr's Avatar
Default Re: ever broke your upper control arm mounting bolts? (Built B16A)
they don't look big enough for the uca bolts unless im miss understanding you
Old May 26, 2006 | 09:45 AM
Built B16A's Avatar
Default Re: ever broke your upper control arm mounting bolts? (mrtoastyjr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr &raquo;</TD></TR><TR><TD CLASS="quote">they don't look big enough for the uca bolts unless im miss understanding you</TD></TR></TABLE>
the ones in the pictures are obviously machince screws.. they come in all sizes.
Old May 26, 2006 | 11:58 AM
rsca_crx's Avatar
that doesnt seem like the best idea for suspension components.
Dragline
Jul 12, 2005 04:46 PM
Blazin Civic
11
Jun 20, 2005 03:15 PM
monotone485
Oct 21, 2003 02:00 PM
