Why no vtec?
Old Apr 13, 2002 | 12:23 PM
NSX Bob's Avatar
New User
Default Why no vtec?
I was taking a 90 degree left turn from a standstill, entirely in 1st gear. When exiting the turn, I hit the gas and the car bogged, obviously not in vtec, so I upshifted (rpm's had been at around 7-7,500). Anyway, I thought I had crossed over to the large cam at the correct rpm, but it feels like the car just "fell out" of vtec range. I checked the oil, and it wasn't extrodinarily low, and the car had no problem at any other time. BTW, yes, it was warmed up. Is it possible the oil pressure was never high enough to crossover and I just didn't notice, or is it something else. Thanks for any helpful responses, as this has never happened before during hard cornering, i.e. autro-x.
Old Apr 13, 2002 | 12:33 PM
csufweed's Avatar
Default Re: Why no vtec? (Itr00-1374)
vtec solenoid maybe...
Old Apr 13, 2002 | 12:35 PM
ZygSpeed's Avatar
Default Re: Why no vtec? (csufweed)
Gotta watch that oil level, ... seriously!
Were you maybe low on gas, too?
Old Apr 13, 2002 | 02:07 PM
nfn15037's Avatar
Default Re: Why no vtec? (Zygspeed)
Yeah, the oil might have been slightly low, causing the pickup to go dry for a second. This causes a oil pressure drop, disengaging VTEC at the same time i would think.
Old Apr 13, 2002 | 02:39 PM
NSX Bob's Avatar
New User
Well, just added some mobil 1 (I was a little low anyway), so I wili try it again and see what happens. BTW, there was 1/2 tank of gas, so that definetly wasn't the issue.
Old Apr 13, 2002 | 04:10 PM
HYPE TYPE's Avatar
Check the oil level...the vtec will kick out when the oil level is too low....
tigasin
Nov 14, 2008 11:58 PM
JSpekBB4
Oct 30, 2007 10:23 PM
green_beret
Sep 16, 2006 05:10 AM
zer0zer0 TypeR
Jun 6, 2002 04:53 AM
filetofit
Mar 27, 2002 08:38 PM
