Sweat The Small Stuff
Old May 25, 2006 | 09:13 PM
comingupfast's Avatar
Default Sweat The Small Stuff
So I got my JDM OBD1 B16A (92-95) on the way, full swap plus skunk2 OBD2A-OBD1 jumper harness $2,100...But anyway the point of this thread is I am having troubles figuring out which axles, shift linkage, and mounts to get. I have a budget so I can't get all Hasport stuff or believe me I would. If somebody has parts they are getting rid of that will help me or knows of a place to get them please let me know.
Old May 25, 2006 | 09:47 PM
Frozen E's Avatar
H-T White Ops
raxles.com for your axles. They make axles specifically made for swaps like yours.
Old May 25, 2006 | 09:54 PM
eXcelonTypeR's Avatar
Default Re: (IslandSi)
GSR shift linkage (thats what i used atleast), theres a JPEG thats floats around that has the mounts and stuff on it
Old May 25, 2006 | 10:18 PM
MrCivic's Avatar
Default Re: (eXcelonTypeR)
Well I'm going to assume you're swapping this into a 96-98 civic since you have the obd2a to obd1 harness. When I got my obd1 b16a complete changeover from hmotorsonline the axles and shift linkage that came with the swap worked fine, so I assume the ones that come with yours should too, unless it doesn't come with them haha. In that case any 94-01 integra shift linkage should work, and for axles i believe del sol vtec ones will work. For mounts I went with Innovative mounts from Passwordjdm, and I love them. They're very solid and I have very little vibration from them. You will need a 99-00 Civic Si rear transmission bracket for sure, should be able to get that from the stealership if you want or i know passwordjdm has them too. You'll want to go with radiator hoses from a del sol VTEC and if you want to keep a/c if you have it you'll want a del sol vtec or crv a/c bracket to use your stock d-series compressor and the rest of the system. It's also good flush the trans and engine and put new fluids in, but i'm sure you knew that lol. I'd suggest OEM honda for the trans fluid and royal purple engine oil, i like that combo a lot on mine. Hope that helps out, pm me if you have any other questions.
Old May 25, 2006 | 10:20 PM
Default Re: (MrCivic)
I just hope they dont have visual inspection in IL cause you'll fail (for street that is). obd-1 into odb-2 street cars aren't legal if im not mistaken??
Old May 25, 2006 | 10:35 PM
MrCivic's Avatar
Yeah I believe in states with inspection the engine being swapped into a car has to be either the same year or newer. No problem for me, though, no inspection in South Dakota.
Old May 28, 2006 | 07:05 PM
I'm not to worried about the visual inspection I'm not going to be selling the car anytime soon. Thanks for all the info I will be posting pics of the removal of the baby d-series and the installation of the big brother b-series. Lets all hope it goes as planned!!!!
Old May 29, 2006 | 07:59 AM
axtran's Avatar
no offense but a better idea if you're on a budget is to wait out a lil more and just get a B18C1
Old May 29, 2006 | 08:18 AM
92Hizzle's Avatar
Default Re: (axtran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran &raquo;</TD></TR><TR><TD CLASS="quote">no offense but a better idea if you're on a budget is to wait out a lil more and just get a B18C1</TD></TR></TABLE>
?!?!? How would that help save money, he would still be looking for axles, a shift linkage, and a mount kit, and he would have paid twice as much for the motor swap as the B16A.
Old May 29, 2006 | 08:34 AM
.Grimace's Avatar
footwork mastery
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrCivic &raquo;</TD></TR><TR><TD CLASS="quote"> You will need a 99-00 Civic Si rear transmission bracket for sure... </TD></TR></TABLE>
my friend just did this and he had to use a 94-01 integra one....
Old May 29, 2006 | 10:28 AM
B18C EG2's Avatar
From: Home Of The Players And PIMPS, IN, united states
Default Re: (PurpleEKHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PurpleEKHatch &raquo;</TD></TR><TR><TD CLASS="quote">
my friend just did this and he had to use a 94-01 integra one....</TD></TR></TABLE>
your proboly talking about the rear mount on the motor.....
were talking about the mount that bolts to the car itself...then you bolt the motor to it...if your friend did use an integra one for that i dono how his motor is sitting in there...
Old May 30, 2006 | 10:59 AM
Another question has arised for me...Since it is an OBD1 motor and I'm reusing the stock EX harness (OBD2A) do I have to connect the second O2 sensor? I ask this because I need to get a 2.5" test pipe for the JDM header and I don't want to mess with and O2 simulator...somebody help me out here!
Old May 31, 2006 | 11:33 PM
Bump for help please...
10sec4door
Northeast (Sales)
Aug 4, 2010 04:46 PM
crx4ever
Jun 12, 2006 09:45 PM
nk2k2
Feb 9, 2006 04:27 PM
billyonaire
Oct 3, 2004 05:51 AM
trexb16
Nov 28, 2003 11:01 AM
