A Honda Tuner's way to tune his carbed motorcycle
Old May 25, 2006 | 08:36 PM
bdavis's Avatar
Default A Honda Tuner's way to tune his carbed motorcycle
I put the wideband on it!!
Let me say this is the first time I have ever touched a carb before in my life.
Here is the quick run down.
Bought a 93 600 kat last year, good starter bike, fun times will one carb got all fucked. Thought it was an ignition related miss, ended up being the carb. expletive that thing. I bought a 750 kat motor. Put my full yoshi pipe on it and stuck it in the frame. the 750 carbs were trashed. Finally tracked down some 91 gsxr carbs. they fit kinda, had to use gsxr boots, throttle cable, etc. they are taller and hit the petcock on the tank, so i used some honda axle nuts to space the tank up a bit
got it running, ran all fucked up (127.5 jest), put smaller jets (112.5) in thinking it was running pig rich and it got worse. put some 137.5 jets in, woohoo it runs. still a little messed up so i put the wideband on it. lean at idle, lean at wot. put some 145's in. better, but still lean. a/f's shoot to like 17 afr under wot above 5k. damn. i'm gonna pick up some 155's and maybe 165's tomorrow. ill probably go with the 165's first. i'd like to see the thing go rich. im gonna shoot for 12.5-13.5.
also adjusted the idle screws. purrs like a kitten with a 14.4 afr at about 3 1/2 screws out.
tried all day to find filter pods for it, but no such luck. so i ripped the little boots out of the air box, stuck them on the carbs and then made a little block off plate to keep the carbs separated from tire and stuff.
im thinking of making some lil' velocity stacks for it. i still have the 2.25 in press tool for flaring out the ends from an intake mani i designed for my thesis. just gonna run some numbers and see what i want
any ideas on what jets to use??
Old May 25, 2006 | 11:43 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: A Honda Tuner's way to tune his carbed motorcycle (bdavis)
COOL!
Old May 26, 2006 | 07:58 AM
bdavis's Avatar
Default Re: A Honda Tuner's way to tune his carbed motorcycle (d-a-n-t-e)
165's woohoo! mid 13's above 7-8k. spikes to about 15 afr around 5-6k.
feels much better, gonna try some 175's later. i think that will drop my spike to high 13's and make my top end about mid 12's.
i think these bike motors can handle leaner conditions than car motors, but i'd rather sacrifice that 1-2hp with the richer conditiona for the safety
Old May 26, 2006 | 08:14 AM
MSchu's Avatar
My Name is Nobody
sounds like your moving in the right direction, just keep an eye on the plugs... don't run a motor on the street with out filters,your risking permanent damage otherwise... and resink carbs after a indi filter install. You know how to do a plug check right?
Old May 26, 2006 | 08:21 AM
MSchu's Avatar
My Name is Nobody
Another thing, carbs are great... keep an eye open for high performance after market carbs on the bay, there are some GREAT DEALS on high end race carbs. I have seen $1500-$2000 set ups going for $300-$500. Makes me want to get a carb bike just to take advantage of these deals
Old May 26, 2006 | 08:47 AM
ragnaroek's Avatar
cthulward
Default Re: A Honda Tuner's way to tune his carbed motorcycle (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">Another thing, carbs are great... </TD></TR></TABLE>
i HATE dealing with carbs. if i ever start tweaking the motor on my bike, ill be converting it to efi...
Old May 26, 2006 | 08:56 AM
falcongsr's Avatar
What is this crap?
i've always wanted to tune my bike with my wideband off my turbo teg. very cool stuff.
my big bike has a severe heat problem, that is made worse by the catalytic convertors down by your feet. if i remove them when I add an aftermarket exhaust, i should be able to screw in the wideband o2 in the port that the factory o2 sensor is plugged into and dial things in with a power commander hopefully.
whats a good target A/F for cruising? probably stoich 14.7? I'd heard bikes can run leaner without pinging due to less mass = less load, but the higher compression ratios and stricter emissions laws (running lean makes NOx emissions spike doesnt it?) nowadays may negate that.
Old May 26, 2006 | 09:00 AM
bdavis's Avatar
Default Re: A Honda Tuner's way to tune his carbed motorcycle (falcongsr)
yes i know how to check plugs. i read them in my turbo civic all the time
the way i have the carbs separated, there is no way for **** to get to them. im gonna try it for now. besides i NEED new tires
just picked up some 172.5's , maybe throw them on later today.
Old May 26, 2006 | 09:10 AM
MSchu's Avatar
My Name is Nobody
cool, but I'm not talking about reading them, I am talking about doing a plug check.
Old May 26, 2006 | 09:47 AM
TXcivic96's Avatar
did you try adjusting the pilot adjustment screws on the bottem of the carbs?
Old May 26, 2006 | 09:52 AM
MSchu's Avatar
My Name is Nobody
Default Re: A Honda Tuner's way to tune his carbed motorcycle (jdmboostedlude)
there are generally pilot jets, main jets, needles, and an air fuel screw... YOu should do your plug checks at WOT under load... kill the engine at WOT, coast home, and read as normal.
Old May 26, 2006 | 11:09 AM
bdavis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">YOu should do your plug checks at WOT under load... kill the engine at WOT, coast home, and read as normal.</TD></TR></TABLE>
yep me too
i adjusted the pilot screws to get a nice a/f at idle. i went the wrong way at first 18-19 afr
im getting some new tires today.
Old May 26, 2006 | 12:47 PM
The_Head's Avatar
Where did you stick the probe? I tryed this last year with my YZF, I just stuck the probe up the exhaust as far as I could and rode around to see what happened. It was 13-14.5 on partial and 12.5 at WOT, so I figured it was good to go.
Old May 26, 2006 | 02:27 PM
bdavis's Avatar
Default Re: A Honda Tuner's way to tune his carbed motorcycle (The_Head)
it stuck it about 8-10 inches after the collector. basically the easiest place for me to weld it
i think ill throw the bigger jets in tomorrow
Old May 26, 2006 | 07:17 PM
The_Head's Avatar
I modified my airbox (punched holes in strategic locations to flow more air) which would require a rejet if I weren't at this altitude. I think the bike still runs rich... alot of carbon in the exhaust.
Sean Hallahan
Honda Motorcycles
Jun 21, 2019 02:35 AM
efboy
Motorcycles
10
Nov 24, 2012 08:48 AM
herecomesfreddy
Honda Motorcycles
May 31, 2009 05:30 PM
armymp87
Honda Motorcycles
Mar 18, 2008 04:52 PM
92civeg
Honda Motorcycles
Jan 12, 2006 12:53 PM
