did a compression test on my usdm h22a4 today, is this number ok?
Old May 25, 2006 | 07:54 PM
vietdragontekx's Avatar
Default did a compression test on my usdm h22a4 today, is this number ok?
i have a USDM h22a4 motor in my 97 honda prelude right now(just swap it out since i blew my jdm h22a). the motor have 120 K on it.
185,185,190,190
is that good? what the maximum psi on a h22a4?
Old May 25, 2006 | 07:56 PM
M2B4's Avatar
Default Re: did a compression test on my usdm h22a4 today, is this number ok? (vietdragontekx)
its good that there close like that i dont know about the h22a4 but i think the jdm h22a normal comp is liek 220-240 across the board.
Old May 25, 2006 | 07:58 PM
Default Re: did a compression test on my usdm h22a4 today, is this number ok? (M2B4)
yep, i had a jdm h22a and i have 210 across the board.
by the way i did this compression test with full gas pedal to the floor(WOT) with fuel pump fuse taken out and coil wire removed.
Old May 26, 2006 | 07:23 AM
bluedlude's Avatar
i believe according to helms you are at the average values. i have an 01 H22a4 and got only a little higher, between 190 and 200. im planning on doing it again actually this weekend since i used sea foam to C what happened. get back to u on my results
Old May 26, 2006 | 08:00 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (bluedlude)
that's decent,
A jdm h22 has higher compression thus the higher numbers
Old May 26, 2006 | 08:14 AM
TheAccordGuy's Avatar
I just got my JDM h22a rebuilt and im getting 250 across the board.
Old May 26, 2006 | 09:50 AM
98vtec's Avatar
moderator emeritus
Default Re: (TheAccordGuy)
those are nice numbers, your motor is ok
Old May 26, 2006 | 09:55 AM
K-Spec's Avatar
Default Re: (98vtec)
what should the compression be on a healthy H22A4 motor?
Old May 26, 2006 | 10:00 AM
98vtec's Avatar
moderator emeritus
Default Re: (khalal538)
the compression of the motor has alot to do with the actual numbers that comes out. Most usdm motors i have seen are around 195-200.
Old May 26, 2006 | 12:26 PM
Default Re:
is this number good enough so i can go turbo? because im planning to put on my turbo this summer. boosting at 6-7 psi.
Old May 26, 2006 | 12:29 PM
InvaderTrax's Avatar
7 PSI should be safe for that compression with stock pistons/rods
Old May 26, 2006 | 01:05 PM
Default Re: (InvaderTrax)
thx, im still waiting to get jdm h22 block so i can rebuild it.
Old Mar 13, 2007 | 06:17 PM
THC07's Avatar
Default Re: (vietdragontekx)
bringing this thread back from the dead...
So is my 160 across the board bad?? lol, its got me a bit worried. '99 H22A4
runs good though, dunno the dyno #s
Old Mar 14, 2007 | 05:02 AM
Speedra500's Avatar
Default Re: (THC07)
did check it at WOT?
Old Mar 14, 2007 | 09:51 PM
THC07's Avatar
Default Re: (Speedra500)
yup.
Old Mar 14, 2007 | 09:58 PM
mafia's Avatar
Default Re: (THC07)
my bro's b18c5 is 170 across the bord
Old Mar 15, 2007 | 04:52 AM
jdmlude5
Guest
Posts: n/a
yeah that seems alittle low. mine put 250-260 across(h22a) but a4 does have alittke lower compression tho.
Old Mar 15, 2007 | 07:57 AM
Finest's Avatar
Default Re: (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 &raquo;</TD></TR><TR><TD CLASS="quote">bringing this thread back from the dead...
runs good though, dunno the dyno #s</TD></TR></TABLE>
Add a few drops of oil in each cylinder and try the test again.
prelude_93vtec
Jun 15, 2007 12:40 PM
GR
Feb 8, 2006 08:39 PM
93H22APrelude
Jul 31, 2005 05:30 PM
superturboprelude
May 22, 2004 01:57 AM
nos_b16
May 2, 2003 08:24 AM
