IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR?
Old May 25, 2006 | 07:23 PM
My93eghatch89's Avatar
Default IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR?
I have a 93 EG CIVIC HATCHBACK THAT I JUST SWAP'd WITH A INTEGRA MOTOR When I lower my car Should I get Coilovers and Shocks for a 93 Civic Or should I get it for a 98 integra? Wich Do I do plz get @ me soon I am planning on lowering in a couple weeks AIM MSG ME AT My 93 Eg Hatch
Old May 25, 2006 | 07:27 PM
winnerpl's Avatar
no one is gonna aim msg u.
you should get the ones for the civic, the suspension setup has nothing to do with whatever motor you have-Although many parts are interchangable from a 94+ integra to a 92-00 civic. search the forums for more input
silentone's Avatar
Default Re: IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR? (My93eghatch89)
The shocks will bolt right up, they are the same thing.
The springs are the same size but the integra spring rates will be stiffer. It might cause a little uneveness in ride height. But since youre looking at getting coilovers you cant adjust the height of your car.
Either way all eg/dc shock/spring setups are interchangible. Only the rates will differ.
Old May 25, 2006 | 07:39 PM
Paxil4x4's Avatar
Default Re: IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR? (bboyprodigy)
English do you speak it?
Old May 25, 2006 | 07:42 PM
fmrprojects's Avatar
Default Re: IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR? (packthis)
just get springs for an integra. the rates on the springs are different and the motor is a little heavier. so overall it will be best to get the integra suspension
Old May 25, 2006 | 07:48 PM
SiYouLater's Avatar
It doesn't matter what motor you have. If your vehicle is a 93 civic then you should get coilovers for a 93 civic. 92-95 civic suspension will also fit with 94+integra suspension.
Old May 25, 2006 | 07:49 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by packthis &raquo;</TD></TR><TR><TD CLASS="quote">English do you speak it?</TD></TR></TABLE>
What the hell does the title say? And I do not understand the question. If you lower your car, you don't use oem parts.
Old May 25, 2006 | 08:07 PM
Paxil4x4's Avatar
Default Re: IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR? (cambopheonix56)
Witch: somebody with magic powers: somebody, especially a woman, who is supposed to have magical or wonder-working powers that are most often used malevolently
Encarta ® World English Dictionary © & (P) 1998-2004 Microsoft Corporation. All rights reserved.
Wich
"Wich" is not even a word.
If he can use grammar properly he needs to enroll in a ESL class.
Which:
CORE-MEANING: used to ask for something to be identified from a known larger group or range of possibilities
adj Which part of it don’t you understand?
**** Which would you like?
**** Which of the colors do you prefer?
**** At which stage do we start to cut our losses?
1. ****
introduces a relative clause: used to introduce a clause that provides additional information about something previously mentioned
The cabin, which we bought last spring, sits high on the dunes.
A success for which she is to be congratulated.
2. ****
that: used to introduce a relative clause that provides necessary information about its antecedent
Please return the money which I loaned to you.
3. ****
refers back to a phrase or sentence: used to refer back to an entire verb phrase or sentence
Swimming after eating, which I’ve told you not to do, can be very dangerous.
4. adj , ****
one from known set: one of a range of things or possibilities specified or implied by the immediate context
adj I can’t decide which activity would be the most fun.
**** He decided which to buy and paid the money.
5. adj , ****
indicates choice: used to indicate one or any number of things
adj Use which method best suits you.
**** Take which you prefer.
[Old English hwilc , literally “of what
Old May 25, 2006 | 09:04 PM
SiYouLater's Avatar
This is not grammar-tech.com GTFO with that ****.
Old May 25, 2006 | 09:06 PM
E46Kid's Avatar
Default Re: IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR? (99FBPSi)
Get Coilovers for your year civic!
1. 92-00 civic is the same suspension as 94-01 teg
Old May 25, 2006 | 09:19 PM
YeeJ6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by packthis &raquo;</TD></TR><TR><TD CLASS="quote">"Wich" is not even a word.</TD></TR></TABLE> wow, that is just ******* great, because it really helps answer his question... dont post stupid **** that is irrelevant to the question the OP is asking.
you can just use eg coilovers the motor doesnt really matter. just make sure you get some after market struts if you're planning on slamming it
Old May 25, 2006 | 09:20 PM
eXcelonTypeR's Avatar
Default Re: IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR? (EkSi)
I just think you need to step away from the wrenches for a bit and do some general research before getting any further into your car. Goto one of the stickies at the top of this forum and do some learning *no sarcasim intended*. You may know alot cars in general, but it seems that your knowledge of Hondas is limited. I know everyone has to start somewhere, hence the stickies at the top covering the questions that have been beating to death lol.
Old May 25, 2006 | 09:25 PM
Paxil4x4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonspeed &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi &raquo;</TD></TR><TR><TD CLASS="quote">This is not grammar-tech.com GTFO with that ****.</TD></TR></TABLE>
Go expletive yourself
Old May 25, 2006 | 09:34 PM
jaytothen's Avatar
to answer the question, all suspension from a 92+ civic's and 94+ Integra's are the same. With the heavier motor you are definitely going to want something with a stiffer spring rate. IMO I wouldn't go with Tein's, D2's, etc. b/c they are set very conservitive with spring rates and are pretty soft. Omni's have pretty nice rates but with everything going on with the recall's i wouldn't suggest them. Try something like Apex'i where you can have custom spring rates made. hope his helps a little
Old May 25, 2006 | 09:42 PM
entityzero's Avatar
I fail to see the logic in this thread debate. Dude it really all depends on what your gonna be doing with your car? Daily driven? Track? 1/4 mile?
I'll make it simple, most aftermarket performance lowerings springs are already stiffer than OE. Regardless if it was for Civic or Integra. Just buy a set for you civic from a reputable company like Eibach or H&R or whatever you feel worthy. Just make sure you have some good performance shocks to back them up.
Old May 25, 2006 | 09:46 PM
Default Re: IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR? (jaytothen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaytothen &raquo;</TD></TR><TR><TD CLASS="quote">to answer the question, all suspension from a 92+ civic's and 94+ Integra's are the same. </TD></TR></TABLE>
That's not comletely right. The Type-R is slightly different in that it uses different rear LCA's than a LS or GSR Teg. For the front Type-R shocks and springs are the same thou, I know from experiance, ran Type-R full adj. coilovers on my Hatch
Old May 25, 2006 | 11:11 PM
Harryflores's Avatar
Default IF I LOWER MY CAR W-h-ITCH COILOVERS DO I USE FOR MY CAR
since the motor you got is bigger just try to get some tokico shocks ( blue or white whatever u want ) and some skunk2 coils... if u want better... go TEIN Basics ( ) is a little more money but you will see the difference!
Modified by Harryflores at 12:22 AM 5/26/2006
Old May 25, 2006 | 11:18 PM
Don't forget about Camber kits, Control Arms and the alignment !! - Don't be ROOKY
Old May 26, 2006 | 01:37 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by packthis &raquo;</TD></TR><TR><TD CLASS="quote">IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR?
Wich
Which:
1. ****
2. ****
3. ****
4. adj , ****
5. adj , ****
Encarta ® World English Dictionary © & (P) 1998-2004 Microsoft Corporation. All rights reserved.</TD></TR></TABLE>
your gay...way to post copyrighted material ***
Old May 26, 2006 | 09:26 AM
Paxil4x4's Avatar
Default Re: IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR? (thahuhstunna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna &raquo;</TD></TR><TR><TD CLASS="quote">
your gay...way to post copyrighted material ***</TD></TR></TABLE>
you're gay because credit was given to the source. So go have **** sex with your brother
Old May 26, 2006 | 10:14 AM
8520's Avatar
Default Re: IF I LOWER MY CAR W-h-ITCH COILOVERS DO I USE FOR MY CAR (Harryflores)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget about Camber kits, Control Arms and the alignment !! - Don't be ROOKY </TD></TR></TABLE>
Lol, the only thing that is necessary in that list is the alignment. Your tires would be perfectly fine without camber kits, and 90% of control arms are just bling anyways (apart from all that unsprung weight horse ****).
Oh and you spelled "rooky" wrong
And you guys need to give packthis a break. Nothing more annoying than struggling to read some 3rd grader's questions. I find it hard to take my time to answer someone's questions when they can't take the time to use correct grammar and punctuation.
Old May 26, 2006 | 12:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by packthis &raquo;</TD></TR><TR><TD CLASS="quote">you're gay because credit was given to the source. So go have **** sex with your brother </TD></TR></TABLE>
^^ and you spank it fantasizing bout that **** ***
Old May 26, 2006 | 01:07 PM
dynamo's Avatar
If you are referring to spring rates, I would say go with the rates for the motor for the front, and the rates for your chassis for the rear. I have a gsr swap in my hatch too, have integra rate springs in the front and civics in the back.
Old May 26, 2006 | 01:25 PM
Sean Juan's Avatar
Old May 26, 2006 | 01:32 PM
Paxil4x4's Avatar
Default Re: IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR? (Grip King)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip King &raquo;</TD></TR><TR><TD CLASS="quote">
Thats right its Teen-tech with bad grammer and no teeth
