SOHC ZC VTEC valve cover bolts
I was going to change out the grommets on this valve cover cuz they're leaking. Then I realized that because of the little lip at the end, you can't take the grommets off. So I have to replace the whole bolt? What application do I ask for? I asked for Si/EX. My original DX motor bolts accepted this style of grommets. I guess I can just go to the junkyard and swap the bolts?
JDM valve cover bolts are teh suck! Unless you want to buy them off me...
ehhh... you can take those off, and put them on... but its a pain in the ***... lube them up first and rotate them until they slip over the lip... they are like a dollar each, instead of like 3 or up to 6 each bolt...
crxaddikt
Sep 19, 2002 10:08 PM
