need help removing bottom trim around hatch glass
Old May 25, 2006 | 06:27 PM
eda6's Avatar
Default need help removing bottom trim around hatch glass
how do you remove the bottom trim piece around the hatch glass?
The l, r, and top were easy to remove but it looks like i might have to remove the window to get this bottom piece off.
searched and found a thread about this for the crx. 2point2 said the bottom piece slides out, but i don't see how.
am i missing something or do i need to remove the window from the hatch?
my ED6 and I thank you in advance.
Old May 26, 2006 | 02:39 AM
eda6's Avatar
Default Re: need help removing bottom trim around hatch glass (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">how do you remove the bottom trim piece around the hatch glass?
Old May 26, 2006 | 10:39 AM
eda6's Avatar
went to the junkyard today and figured it out. it's the same for hatches.
remove the endcaps (1 on each side), pick a side and slightly pull it towards you, slide the moulding out from the l or r. be careful when removing the endcaps so you can reuse them. also be careful when sliding the moulding out. It's very thin and easy to bend.
hate!
Mar 4, 2011 09:09 PM
InTheLBC20
Jul 6, 2009 08:36 PM
msinsky14
Dec 30, 2007 06:10 PM
13BT
Oct 24, 2006 06:40 AM
Civic44
10
Jan 18, 2003 02:33 PM
