When 462whp isnt enough, race gas - JG-Fab.com
This is the Stock Longblock (factory head gasket) s2k that just made 462 whp on pump gas
Incase yall dont rember which s2k it was here are some pics of it
Here is the dyno sheet you are all waiting on
This was on c16 gas
Now once I get a built engine as a backup I will be brave enough to go higher
-James
This was on c16 gas
-James
you have the ***** of a lion.
sick---
yeah what octane was the first reading on? also what are you using interms of engine management...
sick---
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zangiefisgod »</TD></TR><TR><TD CLASS="quote">Very linear
What size wastegate?</TD></TR></TABLE>
44mm most likely
What size wastegate?</TD></TR></TABLE>44mm most likely
umm hoiw miuch PSI was ithis on and show the AF so we can be truely impressed! Also what engine management are you uisiing since you have no map sensor plgged in from wihat i see
Well I am getting rid of this air water intercooler and turbo
about to go bigger and better
Should have car up and running in a month or so, things to look for under the hood next
New custom air air intercooler that flows enough for 1000hp (core size 18" long, 12" tall, 4.5" thick)
GT40R or GT42R turbo which ever I feel will do the trick
-James
-James
what clutch are you using and is there any rear-end work if you dont mind me asking? Great numbers btw! Its got me thinking hard about going FI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JG-Fabrications »</TD></TR><TR><TD CLASS="quote">rochester 1000cc injectors
-James</TD></TR></TABLE>
About to be
I got tired of braking axles so I am putting on some driveshaftshop stage 5 axles
and driveshaft, we are also going to mod the diff our selves to beef it up (think oversized arp studds and billet 4140 chromoly housings for the diff
Also am working at getting a competition clutch twin disc as what I have now is starting to slip
-James
About to be
)Also am working at getting a competition clutch twin disc as what I have now is starting to slip
-James
Well car sat in the drive for over a month with broken axle I am finally getting a chance to work on it again
so far everything that has happend over this weekend
This is my new air air intercooler I built for it along with my custom griffen racing radiator
Core size on intercooler 18" long 12" tall 4.5" thick (rated at 950whp from precision)
Core size on radiator 18" long 12" tall 2.5" thick (holds more than 2x the water of the factory radiator) It is fully shoured and I have a fal fan for it that flows 1750 cfm
I should have the car running again this week some time (I only get to work on it after 7pm on week days and on weekends)
When it is running again we will take it back for retune, gonna see how much power that small 60-1 bb will really push out (hope to get another 100 out of it if possible)
-James
-James
As you can see ac is coming out to make room for this new setup
Some things to watch out for later this month
AP2 bumper swap (as you can see the intercooler is mounted really far back so that the bumper wont need to be cut
Also am going to have the hood pin on because we had to do away with the radiator core support
Also am working on getting a rps twin disc carbon clutch for it and a turboxs quad stage boost controller
NOTE: this is still a 100% bone stock engine
the only engine mods are
hondata intake mani gasket
custom turbo setup by me
-James
-James
Well I will see if I can make it back to the dyno this sunday
I will let you all know how it goes, maybe I can get a vid camera by then so I can have a vid for you all
-James
-James
