Need help - alignment kits
Old May 25, 2006 | 06:06 PM
DomenEK's Avatar
Default Need help - alignment kits
My tyres are wearing badly on the inside edges - they're now bald. I realise this is a result of having the car sitting low. The inside edges are working really hard - there are crease marks, and one of the sidewalls has split. So I'm badly overdue for new tyres.
I took my car in to check a few things out that were concerning me, apart from this (clunking noises from the front sussy, etc....), and I discovered a lot more is needing attention than I originally thought.
So apart from needing a new shock mount and endlinks for the front swaybar, I discover that I will need front and rear alignment adjustment kits to fix the tyre wear issue. I'd like to get this before, or very soon after I get new tyres. The kits I need are replacement control arms, and are fully adjustable.
My problem is that these are so damn expensive - I was quoted approx. AUS$1.5k front and AUS$600 rear, so I was thinking, maybe if I can source them from somewhere (international, e.g. U.S.) and take it back to get them istalled I may save a bit.
I have been doing a bit of searching around and found some kits that would suit. Basically I've put it down to getting something from Skunk 2, SPC, Ingalls or Omni Power kits for the front and rear camber kits. Any other brands you would recommend?
Being in Australia and new to sourcing parts from overseas, I'm after some local knowledge. What do you guys think of these sites:
Import Auto Performance
Just Air Bag It!
Modacar
Are there any other stores/places that you would recommend I check out?
Thanks in advance for your help.
MrHeeltoe
Suspension & Brakes
May 7, 2010 05:02 PM
TokyoStatus
Jan 9, 2008 04:27 PM
DomenEK
Suspension & Brakes
May 27, 2006 06:49 PM
agent007ppk
Feb 28, 2004 09:31 PM
SIowner
15
Dec 26, 2003 05:54 AM
