Someone help me!!
Old May 25, 2006 | 06:03 PM
20_sec.hatch's Avatar
Default Someone help me!!
I just did a D16z6 swap in my 92 cx everything is in placei have power to everything but seems af if comp is not sending sinals out. I did however try using 2 other comps and same thing happened . So I have checked all my fuses (in car and under hood), checked the comp, checked to see if all wires were pluged in, checked for power to everything. So now what?? I did do an integra dash swap and everything works on it. Also out of my gauge cluster i am not getting any check engine light or oil lights, the only one that comes on is the brake light. I do know the cluster works 100% i checked it in my integra. This is all i have to say
Old May 25, 2006 | 09:03 PM
Simple's Avatar
Default Re: Someone help me!! (20_sec.hatch)
the computer isnt sending signals.... this is VERY broad... WHAT is your car doing? you'll get more help if you have spacific problems.
Old May 26, 2006 | 01:40 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20_sec.hatch &raquo;</TD></TR><TR><TD CLASS="quote">I just did a D16z6 swap in my 92 cx everything is in placei have power to everything but seems af if comp is not sending sinals out. I did however try using 2 other comps and same thing happened . So I have checked all my fuses (in car and under hood), checked the comp, checked to see if all wires were pluged in, checked for power to everything. So now what?? I did do an integra dash swap and everything works on it. Also out of my gauge cluster i am not getting any check engine light or oil lights, the only one that comes on is the brake light. I do know the cluster works 100% i checked it in my integra. This is all i have to say </TD></TR></TABLE>
from your post it sounds like everything is ok... what exactly is the problem?
Old May 26, 2006 | 04:10 AM
The car wont start, the injectors are not getting fuel becaust the fuel pump is not comeing on, the starter is not turning over. I can hear it clicking a relay under the hood but nothing after that????????????????
Old May 26, 2006 | 08:54 AM
Simple's Avatar
Default Re: (20_sec.hatch)
check your battery... sounds like its shot, could be why you get that click, but no start.
Old May 26, 2006 | 08:55 AM
JDM JUICE's Avatar
yea nice man.. write a whole damn paragraph and dont put what the problem is. and yea i know i read the other post already. i cant help you i dont help idiots
Old May 26, 2006 | 09:00 AM
cyang08's Avatar
you don't help idiots, sounds like you don't help anyone by writing that. but back to the question try to explain the problem better. make sure all your grounds are good and clean, check your injectors, and do an all around check if your not sure what it is.
Old May 26, 2006 | 09:02 AM
tatmark1's Avatar
i think you answered your own ? check/replace your fuel pump
Old May 26, 2006 | 03:16 PM
well i found my problem i had a bad engine ground!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks for the help.
Old May 26, 2006 | 03:21 PM
sicky's Avatar
grammer nawzi
Default Re: (Honda Civic DX Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Civic DX Guy &raquo;</TD></TR><TR><TD CLASS="quote">yea nice man.. write a whole damn paragraph and dont put what the problem is. and yea i know i read the other post already. i cant help you i dont help idiots</TD></TR></TABLE>
What a ******* waste of a post. Stop flexing you damn E-muscles and don't talk **** like you've been here for years, actually, people that have been here for years don't belittle like that. People like you should get banned. GTFO
tatmark1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20_sec.hatch &raquo;</TD></TR><TR><TD CLASS="quote">well i found my problem i had a bad engine ground!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks for the help.</TD></TR></TABLE>
91hatchcivic
Lighting
Apr 14, 2008 11:16 AM
DoWnfall
Mar 31, 2008 08:18 PM
my92hondasucks
11
Jul 26, 2006 03:54 PM
hondaman25
Feb 12, 2006 03:29 PM
Not_So_JDM
Apr 1, 2005 10:16 AM
