Axles? Or something else?
Old May 25, 2006 | 04:54 PM
CRISIS's Avatar
Default Axles? Or something else?
I have an automatic eg sedan and when i hit the gas hard it makes a clicking sound. But it is very weird because it is not consistent. Today i was driving and i wanted to experiment a little. So i drove in D and sure enough, it was there. Drove and them shifted to N and reved to like 5k. Turned corners while doing both of those as well. The only time it made noise was when it was in drive. Do you guys think it's the axle?
Old May 25, 2006 | 04:56 PM
B16b-EJ8's Avatar
Have a smilar clicking sound would also like to know...99 Ex
Old May 25, 2006 | 05:01 PM
Slamaccord's Avatar
Default Re: (ProjectNoob)
Bad CV joints. Would be my guess.
Check underneath and look at cv boots, are they torn?
Old May 25, 2006 | 05:12 PM
CRISIS's Avatar
Default Re: (Slamaccord)
I know my steering rack boot is torn. But my cv boots look fine. At least i think they do. Not really sure where they are. The cv joint would be replaced as well when the axle is done, correct? Or not?
Old May 25, 2006 | 05:14 PM
Slamaccord's Avatar
Default Re: (Slamaccord) (CRISIS)
Well clicking when turning is an indication of outer c/v joint damage.
Clicking while going straight and vibrations is an indication of inner joint
damage.
I would just narrow it down to which side it is and get a reman axle for like 50 bucks plus core charge.
Old May 25, 2006 | 05:23 PM
CRISIS's Avatar
Default Re: (Slamaccord) (Slamaccord)
Will do. But are the cv joints included? Or are they a seperate item?
Old May 25, 2006 | 05:24 PM
tatmark1's Avatar
yes its part of the axle
Old May 25, 2006 | 05:43 PM
schardbody's Avatar
most likely an axle, but dont rule out the infamous differantial noise.
Old May 25, 2006 | 06:00 PM
akstunt600's Avatar
Default Re: (schardbody)
i had a 97 ek auto and it also made the exact same noise u r describing, i am full time mechanic too and just neglected to change my axels b/c i was planning to do an auto to manual. well good thing i made it through the winter when it was still auto b/c the noise turned out to be the differential ring gear or final drive gear. when i swapped in my new trans the sound was no longer, even though my axels were beat up and one had a torn boot
i seriously thought it was my axels though, it never occured to me that i could have cracked the final drive in an auto, and recently anoither auto ek came to shop with the same noise. checked his axels and told him the bad news. im begging to think this a problem for auto 92-98.
Old May 29, 2006 | 05:41 PM
CRISIS's Avatar
Default Re: (akstunt600)
Also when i am cruising at about 25 to 35 mph my car vibrates like crazy. I have to hit the throttle to make it stop or let off the throttle completely. It kinda feels like my car wants to die and like the suspension wants to fall apart. Any ideas?
Old May 31, 2006 | 08:06 AM
CRISIS's Avatar
Default Re: Axles? Or something else? (CRISIS)
Bump!
Old May 31, 2006 | 09:10 AM
94hatchling's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord &raquo;</TD></TR><TR><TD CLASS="quote">Well clicking when turning is an indication of outer c/v joint damage.
damage. </TD></TR></TABLE>
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRISIS &raquo;</TD></TR><TR><TD CLASS="quote">Also when i am cruising at about 25 to 35 mph my car vibrates like crazy. I have to hit the throttle to make it stop or let off the throttle completely. It kinda feels like my car wants to die and like the suspension wants to fall apart. Any ideas?</TD></TR></TABLE>
vibrations at random or certain speeds can indicate a bad axle(s) as well. find which axle is bad, or if both, and replace, and then see if the problem is still there. i believe that both are originating from the same problem. good luck
riceforlife
Suspension & Brakes
13
Dec 12, 2007 11:27 PM
WhiteOnRice
14
Sep 26, 2006 10:16 AM
gospeedgo1
18
Oct 25, 2005 06:25 PM
iridebiketrials
Jun 1, 2003 08:20 PM
B18C-RnVA
Feb 25, 2002 08:30 PM
