Jackson racing supercharger, for a GSR,.... Will it fit a JDM b16a???
I kno this is a bit expensive, but you might want to try calling up HASport and seeing if they will sell you the manifold part for the blower if you own or are able to buy the Gsr blower. because to the best of my knowledge they are the same supercharger just with different intake manifolds. If they send you the kit without the supercharger your set. Good luck. let me kno if that helps at all. Heres a link to the one that hasport sells, but it is the entire kit. http://www.hasport.com/Products/Supercharger.htm just see if they'll sell you the mani.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">no</TD></TR></TABLE>
There are two issues that I'm aware of (there may be even more);
1) The GSR manifold will not bolt up to your b16a head. A major problem. You could buy a new manifold from JR but they are big bucks.
2) The JR GSR kit places the throttle body down low, as it would be with the GSR manifold. If there is clearance in your particular car, this may be a good thing as it doesn't have the restrictive "S" curve tube that would be on a B16 kit. The Hasport JRSC kit does have the "S" curve tube that places the throttle body up high.
Hasport will not want to sell you "parts" from their kit and will just tell you to contact JR. The guys at JR are willing to help, but the costs start adding up REAL fast when trying to re-configure a kit. <U>You would have to get the kit for a real killer price to make it worth while to make all the changes required. Just go to the JR web site and check the price of the manifold alone!!!!!</U>
Wes Vann
Wes Vann
superdgsr
Feb 14, 2004 11:08 AM
