help with Lower control arm
Old May 25, 2006 | 03:02 PM
superman3503's Avatar
Default help with Lower control arm
how do you loosen the lower control arm with out a pry bar? I'll have heard of using a 3/8 wrench.
Old May 25, 2006 | 03:04 PM
Slamaccord's Avatar
Default Re: help with Lower control arm (superman3503)
Do you mean loosen the bolt?
Old May 25, 2006 | 03:08 PM
Default Re: help with Lower control arm (Slamaccord)
i got the bolt but it still stuck together.
Old May 25, 2006 | 03:11 PM
Slamaccord's Avatar
A long sturdy flat head screw driver usually works.
Don't be affraid to use a hammer either.
If you are attempting to break the taper on the lower ball joint. I find the best way is to strike the lower control just the below the lower ball.
Make sure you do not strike the threads causing damage.
Old May 25, 2006 | 03:12 PM
fmrprojects's Avatar
to get the bolt outta the whole just use a combo and put it behind the head and hammer it out. the LCA should just fall off with a nudge
Old May 25, 2006 | 03:26 PM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superman3503 &raquo;</TD></TR><TR><TD CLASS="quote">how do you loosen the lower control arm with out a pry bar? I'll have heard of using a 3/8 wrench.</TD></TR></TABLE>
more detals, front / rear? what cant you get done and what did you do already?
daniel-em1
Suspension & Brakes
Jun 13, 2011 02:41 AM
butter99
27
Nov 28, 2008 04:53 PM
RTW DC2R
Feb 23, 2007 07:30 AM
jojowasha
Jan 14, 2007 01:49 PM
PabloDiablo
Apr 21, 2004 05:05 PM
