Stage 1 cams?
Old May 25, 2006 | 02:46 PM
jimmy vtec's Avatar
Default Stage 1 cams?
Iam thinking of getting stage 1 skunk2 cams for my del sol VTI. I have already got
cat back exhaust
de-cat
4-2-1 manifold
AEM cai
When i come to fit the cams is it just case of putting the new ones in and setting the timing up? Will it run alright ? Would u recommend putting adjustable cam gears on at the same time? And when i have fitted them i was planning to have some sort of ECU upgrade and have the car mapped, is this worthwhile on a car with these mods? And at a guess what kind of power (flywheel) should i be making from this spec?
Old May 25, 2006 | 03:02 PM
fmrprojects's Avatar
Default Re: Stage 1 cams? (jimmy vtec)
yeah that will be good. just get it tuned after and make sure you torque everything to spec.
Old May 25, 2006 | 03:12 PM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy vtec &raquo;</TD></TR><TR><TD CLASS="quote">Iam thinking of getting stage 1 skunk2 cams for my del sol VTI. I have already got
cat back exhaust
de-cat
4-2-1 manifold
AEM cai
When i come to fit the cams is it just case of putting the new ones in and setting the timing up? Will it run alright ? Would u recommend putting adjustable cam gears on at the same time? And when i have fitted them i was planning to have some sort of ECU upgrade and have the car mapped, is this worthwhile on a car with these mods? And at a guess what kind of power (flywheel) should i be making from this spec? </TD></TR></TABLE>
don't forget the valve springs and retainers as well
Old May 26, 2006 | 08:16 AM
jimmy vtec's Avatar
I thought the stage 1 cams did'nt require the springs and retainers?
Old May 26, 2006 | 08:25 AM
VHOA's Avatar
Default Re: (jimmy vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy vtec &raquo;</TD></TR><TR><TD CLASS="quote">I thought the stage 1 cams did'nt require the springs and retainers? </TD></TR></TABLE>
yea you should be fine without them
get a cam gear and get it tuned and you will be happy with them
Old May 27, 2006 | 04:31 AM
jimmy vtec's Avatar
what do u think about somthing like an hondata s100 etc is it going to make much diffrence on my car?
Old May 27, 2006 | 08:50 AM
VHOA's Avatar
if you have after market cams yes a good tuning program will be a huge difference
Old May 27, 2006 | 12:13 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy vtec &raquo;</TD></TR><TR><TD CLASS="quote">what do u think about somthing like an hondata s100 etc is it going to make much diffrence on my car?</TD></TR></TABLE>
tuning is important to the life of ur engine when u use aftermarket internals.
and correct assembly. i say get it, if u know someone that knows how to use it.
Old May 29, 2006 | 09:19 AM
jimmy vtec's Avatar
Thanks for the info its been really helpful, ive tried asking on other forums but people just seem to ignore my posts. Nice to know i can get answers to my question from people who no what there talking about.
snowseeker
Sep 7, 2005 09:18 PM
red civic standard
14
May 8, 2005 09:04 PM
rodimus
86
Mar 23, 2005 10:46 AM
riceball777
Oct 19, 2003 09:53 PM
