head bolt striped HELP HELP!!
Old May 25, 2006 | 01:41 PM
JDM Vision's Avatar
Default head bolt striped HELP HELP!!
i have a 99 LS engine i need to replace the head gasket and 1 of the bolt heads are striped i have no clue what to do i called redzone and they said to try and tap in a 13mm that did not work so not im stuck with a strpied 14mm bolt in my head and i got this engine YESTERDAY !!!
Old May 25, 2006 | 01:43 PM
JDM Vision's Avatar
Default Re: head bolt striped HELP HELP!! (JDM Vision)
bump
Old May 25, 2006 | 01:53 PM
Slamaccord's Avatar
Well if you have a bolt or stud that is stripped you would want to use a dye.
If its a nut you want to use a tap.
Old May 25, 2006 | 02:18 PM
JDM Vision's Avatar
Default Re: head bolt striped HELP HELP!! (Slamaccord)
thank you im gonna look into geting a dye does anyone have anyother methods of doing this ?
where can i find a dye ?
Old May 25, 2006 | 02:33 PM
JDM Vision's Avatar
bump
Old May 25, 2006 | 02:52 PM
tatmark1's Avatar
is it the hole in block thats stipped or head of bolt or threads of bolt?
nevermind i se you said bolt head now... no die is goint to do anything for that.
drill into it, reverse tap it and put in a reverse threaded bolt and crank it out.
make sure everything else is taped off so no shavings get into anything
Old May 25, 2006 | 02:59 PM
97_hatch's Avatar
I'm not too sure but maybe you can use a bolt out type of socket that is meant for stripped nuts.. It's a special socket used for stripped nuts.. Got my set at sears..
That's what I always use to get my stripped nuts out.. But you gotta hammer it on though..
my 2cents
Old May 25, 2006 | 03:18 PM
JDM Vision's Avatar
Default Re: (97_hatch)
cool thanks guys
Old May 25, 2006 | 03:31 PM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97_hatch &raquo;</TD></TR><TR><TD CLASS="quote">I'm not too sure but maybe you can use a bolt out type of socket that is meant for stripped nuts.. It's a special socket used for stripped nuts.. Got my set at sears..
my 2cents</TD></TR></TABLE>
yeah those things have saved my *** a couple times they work good if you hammer it on real solid.
Old May 25, 2006 | 03:38 PM
tatmark1's Avatar
Default Re: (The Internet Tough Guy)
glad somebody does i always strip those damn things out
Rease3
Jul 21, 2009 06:04 AM
racerxh00
Oct 14, 2008 06:45 AM
vodkas22
May 31, 2006 03:32 PM
TheJediMex
Apr 14, 2003 08:23 PM
itr501
Honda Motorcycles
Nov 17, 2002 05:26 PM
