Help! Fuel line into fuel filter busted
Old May 25, 2006 | 01:24 PM
2-7offsuit's Avatar
Default Help! Fuel line into fuel filter busted
I was trying to relpace the fuel filter on my '93 si and the hardline from the fuel tank broke the top of the filter off with it. I know that sounds crazy, but it was on there that tight. I've read through so many posts about replacing the stock line with a ss line, but I don't care about that. I'm wondering what fitting is needed to run directly into the fuel filter? Is the stock line supposed to be flared to 45 or 37 degrees? Any other suggestions would be appreciated. I'm Just trying to fix this as cheaply and quickly as possible.
Old May 25, 2006 | 01:27 PM
hybridej7's Avatar
Default Re: Help! Fuel line into fuel filter busted (2-7offsuit)
i replaced mine with a stainless line, looks great but gives no performance. im sure you can buy an exact replacement that has the fittings on it......
Old May 25, 2006 | 01:38 PM
2-7offsuit's Avatar
You mean the whole line? From the filter to the tank? The local junkyard wants $75 which is too much. I'm hoping there's an easier way than replacing the whole line.
ODbuilt
Apr 26, 2014 12:50 PM
kid_02131
Oct 3, 2012 12:13 AM
nWilk666
Feb 1, 2012 12:01 PM
memphisfuk
Jun 8, 2008 01:20 PM
Ubermensch
Sep 24, 2001 07:50 AM
