HELP Check Engine (codes 1 & 43)
Old May 25, 2006 | 12:34 PM
sickvtec's Avatar
Default HELP Check Engine (codes 1 & 43)
Any1 had that problem b4? my 92 civic is throwin (Code 1) and (Code 43) n as im concerned code 1 is o2 sensor and code 43 is fuel supply system, first i got code 43 then after awhile i got code 1, when driving and i hit the gas it seems like it doesnt want to go anywhere until like 2 seconds after it pulls like it should in the 1st place.. now ma question is how can i get this problem solved ill apreciate the help!
Old May 25, 2006 | 01:16 PM
hybridej7's Avatar
Default Re: HELP Check Engine (sickvtec)
code 1 is for the O2 sensor, getting it randomly in my car now....... search on here, im sure you can find an answer for the code 43......
Old May 25, 2006 | 02:39 PM
sickvtec's Avatar
Default Re: HELP Check Engine (hybridej7)
i know what the codes are just need to knoe how to fix code 43(fuel problem) wut exacly do i gotta do, change fuel pump etc..any1 else got ideas
Old May 25, 2006 | 04:18 PM
sickvtec's Avatar
Update:
its getting worst i was drivin just now n when i do a full stop n try to take off i hit the gas n it stutters like its chocking n doesnt wanna take off unless i rev up to like 5grand then pop clutch then it goes away soo basicly on low rpm's its shitty but when i hit the gas harder it seems to be fine unless i let the rpm's drop
Old May 25, 2006 | 05:26 PM
CRISIS's Avatar
Default Re: (sickvtec)
Fuel injectors?
Old May 25, 2006 | 05:33 PM
postman's Avatar
check fuel pressure
Old May 25, 2006 | 06:12 PM
axtran's Avatar
injectors have their own cel - check pump/pressure, maybe a line is leaking? or you have a overstretched throttle cable maybe?
Old May 25, 2006 | 06:22 PM
sickvtec's Avatar
Default Re: (axtran)
No the cable seems fine but ima switch fuel pump n see the results if that dont do ima change fuel filter n see
Old May 25, 2006 | 06:23 PM
prwil3030's Avatar
We did a mini-me swap to my brother in law Del Sol couple of month ago. Recently started throwing the same codes as you, same problem as you, we checked fuel injectors, injector clips, fuel filter, ect. Finally, we decied to change the fuel pump, we installed a b16 fuel pump that I used to have in my civic a while ago. Right after changing the fuel pump, we recet the ecu and no more codes after that. I hope this info resolve your problem, also do the same we did before spend money in a fuel pump, check injectors, clips, fuel filter, ect. Good Luck
Old May 25, 2006 | 06:58 PM
sickvtec's Avatar
Default Re: (prwil3030)
deff will try it thanks
ef9itb
Nov 19, 2007 06:12 PM
george34
Aug 6, 2007 11:36 AM
DC2_JAPAN
17
Jun 19, 2007 12:08 PM
sickvtec
May 31, 2006 07:53 PM
