AT Shifter Interchangeable with Legend?
I have searched and haven't found anything pertaining to this type of interchangeable part. I believe that some Acura Legend parts are interchangeable with Accords, but I was wondering if anyone would have any thoughtful insight to this task.
Basically, I want to swap out the AT shifter + box of my Accord ('95 EX) and replace it with an AT shifter + box from a 1991-1995 Legend. They seem to have similar sizes, but hope someone may know exactly.
Or if possible, could I just swap out the AT shifter ONLY? Like the stock one in the picture.
TIA!
TIA!
I don't see why not, as long as the push to shift feature still works then you should be fine, source one from a junkyard or ebay and worse comes to worse, if it doesn't fit then you're not out a big loss.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knightmare69 »</TD></TR><TR><TD CLASS="quote">I don't see why not, as long as the push to shift feature still works then you should be fine, source one from a junkyard or ebay and worse comes to worse, if it doesn't fit then you're not out a big loss.</TD></TR></TABLE>
Thanks! I may try a local junkyard, but hopefully one will be in good condition.
Anyone else?
Anyone else?
Kyles ej1
14
Oct 2, 2005 09:27 PM
