CAMS
Old Apr 13, 2002 | 09:34 AM
BEEFEDUPACCORD's Avatar
Default CAMS
What will a cam do for a 2002 sohc accord se? also how much do the cost, where to buy them, and what type of cam is best?
Old Apr 13, 2002 | 09:36 AM
John's Avatar
New User
Default Re: CAMS (BEEFEDUPACCORD)
WebCam will grind a specific cam to meet any of your needs...
Old Apr 13, 2002 | 09:50 AM
Big James's Avatar
New User
Default Re: CAMS (DunReit)
WebCam? As in the camera site? LOL. I am trying to figure out if you are serious!
Old Apr 13, 2002 | 09:51 AM
Accord94DX's Avatar
Default Re: CAMS (Big James)
http://www.webcaminc.com/
Old Apr 13, 2002 | 10:11 AM
Big James's Avatar
New User
Default Re: CAMS (Accord94DX)
DOH!
Old Apr 13, 2002 | 10:20 AM
Brandon's Avatar
Life is Suffering
Default Re: CAMS
Does anybody else make cams for the F22b1, if they do, I won't need an H22A1 as badly.
Old Apr 13, 2002 | 12:50 PM
benzcivic99's Avatar
Default Re: CAMS (vtec2k2)
Crower Cams (Crower.com) will regrind you one for approximately $80 a cam lobe. Otherwise, they might have a whole new cam for your car...
Old Apr 13, 2002 | 01:03 PM
smokin rubber's Avatar
Default Re: CAMS (benzcivic99)
so thats 16X$80=1280 dollar$$$$$$$$$$$$
Old Apr 13, 2002 | 01:06 PM
Default Re: CAMS (smokin rubber)
Yeah... Crower would be expensive as hell. Probably worth it... What engine does the SE have?
Old Apr 13, 2002 | 01:42 PM
Nick M's Avatar
There are no new billet cams for the f22. You have to go with a regrind.
Old Apr 13, 2002 | 05:25 PM
4doorH22's Avatar
Default Re: CAMS (HondaSport)
I would go with an aftermarket cam profile like Crower's at first. IIRC they have 3 stages. Choosing custom profiles for the lo and hi lobes is a black art and requires much research and knowledge. Oh I'm talking about Crower's H22 camshafts. I dunno if they make 'em for F22s.
Edit: and you should definitely upgrade your valvetrain if you get some moderate to aggressive cam profiles.
[Modified by 4doorH22, 9:27 PM 4/13/2002]
Old Apr 13, 2002 | 05:42 PM
ArchAngel Sabastian's Avatar
New User
se = f22b2
Old Apr 14, 2002 | 04:47 AM
97accordex's Avatar
If you re-grind a stock cam shaft do you need valve springs with lift to match grind etc.? What else in valve train needs to be modified?
Old Apr 14, 2002 | 09:44 AM
Accord94DX's Avatar
Default Re: CAMS (97accordex)
That depends on how aggresive of a grind you get.
Old Apr 14, 2002 | 10:33 AM
John's Avatar
New User
You won't need performance valve springs unless you plan on getting a custom grind that's aggressive enough to warrant rpms +6500. On a F22B2, you'd have to change the entire cam profile (since there are no VTEC lobes), and I doubt you'd pass emissions. If you have a F22B1 you can increase the high-intake lobe... but as mentioned above, custom cam designs are a black art (although WebCam is quite reputable). Fact of the matter is that the F22 SOHC designs are really difficult to squeeze extra rpms out of... Get a H22.
Old Apr 14, 2002 | 11:09 AM
4doorH22's Avatar
If your cam profile is cut extra agressive, you may need to upgrade springs even if you don't spin above 6,500, I think. A profile may be so sharp that the stock spring just can't close the valve fast enough...
Old Apr 14, 2002 | 01:20 PM
CmptchAV6's Avatar
Default Re: CAMS (Sabastian)
Wouldnt the SE have the F23 engine since it is the 6th gen accord????
se = f22b2
Old Apr 14, 2002 | 06:15 PM
H23 Power's Avatar
Default Re: CAMS (CmptchAV6)
5th gen has a F22B2 and the 6th gen has the F23A1
Stevemyster
Oct 26, 2010 03:48 PM
HFP_racing
11
May 12, 2009 06:12 PM
twiztid00002
Feb 5, 2009 12:01 PM
TurboJdmEF9
May 26, 2006 02:16 PM
DrewQ1
Mar 31, 2004 05:45 PM
