deceleration backfire/ idle problem?? need help.
Old May 25, 2006 | 09:13 AM
GSR4U2NV's Avatar
Default deceleration backfire/ idle problem?? need help.
this just started hapening a couple days ago.....at idle i can hear a slight (what sounds liek a missfire) and on deceleration the car hesitates a bit and backfires sometimes and kinda feels as though its jumping forward. i just replaced the plugs and wires too....what could it be?
coil? ignitor? cap? rotor? something else?
need some quick answers.
Old May 25, 2006 | 09:28 AM
DC5ftmfw's Avatar
Default Re: deceleration backfire/ idle problem?? need help. (GSR4U2NV)
bump...I have the same problem and would like to know what this is.
Old May 25, 2006 | 10:09 AM
GSR4U2NV's Avatar
anybody?
Old May 25, 2006 | 02:51 PM
GSR4U2NV's Avatar
does anyone think they have an idea of what it could be?
Old May 25, 2006 | 05:55 PM
boostedblkef's Avatar
did you check the timing could have jump some teeth just a thought
also does it rev up smooth?
Old May 25, 2006 | 06:09 PM
prwil3030's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">
If that started right after you changed the spark plugs and wires, sounds like you have problem with the firing order. My brother changed his plug wires the other day and the engine started acting wird, he put the wires wrong and the firing order wasnt right. Checked the wires, that might be it.
Old May 25, 2006 | 07:31 PM
GSR4U2NV's Avatar
Default Re: deceleration backfire/ idle problem?? need help. (prwil3030)
no it was fine for a while after i changed the plugs and wires and i was beating on it for a bit then it started acting up on me.
Old May 25, 2006 | 09:02 PM
DC5ftmfw's Avatar
mines been doing it for a while. I've changed the plugs and it still does it just the same. It's in time and it does rev up smooth.
bizmackus
Feb 16, 2007 06:34 PM
WhiteSH
Aug 14, 2006 10:31 AM
jdkornlp
Sep 6, 2005 05:12 PM
NightHawk
16
Apr 16, 2003 05:52 PM
Accord88
Feb 23, 2003 05:53 AM
