Glowing Cat
Old May 25, 2006 | 07:08 AM
Psundberg's Avatar
Default Glowing Cat
Out of no where, my CRX started to cough, sputter and finally died. Smoke came out of the vents and under the hood but no flames. The cat was glowing bright orange. No loss of coolant, did not overheat and no other physical signs. Any suggestions on where to look first?
Old May 25, 2006 | 07:11 AM
b18sihatch's Avatar
Default Re: Glowing Cat (Psundberg)
clogged cat?
Old May 25, 2006 | 08:19 AM
JimBlake's Avatar
Misfiring? That can overheat the catalyst. The unburned fuel along with un-used air will 'burn' inside the cat.
Old May 25, 2006 | 08:37 AM
NITROUSHONDA's Avatar
Default Re: Glowing Cat (JimBlake)
2nd the clogged cat
Old May 25, 2006 | 09:00 AM
LSVTEC 91 Civic's Avatar
Banned
Beat the cat
Old May 25, 2006 | 09:57 AM
egrice's Avatar
go straight pipe w/no cat
Old May 26, 2006 | 04:15 AM
Psundberg's Avatar
Default Re: (egrice)
Thanks for the comments. I'll replace the cat (only $77 through Summit) for starters. I'll also check the cap & rotor since that's a weak spot although just replaced a couple months ago. I appreciate the help.
Old May 26, 2006 | 05:00 AM
JimBlake's Avatar
Default Re: (Psundberg)
Make sure you check if misfiring or running rich caused your cat to overheat & melt/plug. If you don't fix the cause you could mess up the new one.
Old May 26, 2006 | 05:44 AM
StorminMatt's Avatar
Default Re: Glowing Cat (NITROUSHONDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NITROUSHONDA &raquo;</TD></TR><TR><TD CLASS="quote">2nd the clogged cat</TD></TR></TABLE>
Well, if it wasn't clogged before, it is likely clogged now. In any case, check for a misfire like the others said. Also check for distributer codes on your ECU. This can cause your cat to glow red hot.
Old May 26, 2006 | 10:37 AM
t0p_sh0tta's Avatar
Default Re: Glowing Cat (StorminMatt)
Disconnect the car and see if it runs better.
More than likely it is the cat though.
Old May 28, 2006 | 02:32 PM
IVAN93EG's Avatar
the same thing happened to my a while back. i was going to the races and stopped to spray my motor down at the car wash. i must have got water in my plugs cuz when i started to drive it , my car started bogging out making me lose power in every gear. by the time i got home i was doing like 15mph at 6000rpm in 1st just to make it home. when i started checking the car i noticed my cat was glowing red. i let it cool and took it off. i hallowed it out with a pipe and hammer. put it back on. dried my plugs and it drove again. ran like crap till the water worked its way out. fucked my whole weekend up. now i smell more exhaust and when i punch it i fart out a big puff of black smoke. i live in texas so the emission laws are sweet. no sniffer to pass inspection. **** as a matter of fact i got my stickers from some half *** shop that didnt even check my car. the cat looks stock but its not. i wonder if i lost power by this?
Old May 28, 2006 | 09:28 PM
Smoke_em's Avatar
From: Inland empire, E.L.A, Douglasville GA, ca, u.s
Default Re: Glowing Cat (IVAN93EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVAN93EG &raquo;</TD></TR><TR><TD CLASS="quote">the same thing happened to my a while back. i was going to the races and stopped to spray my motor down at the car wash. i must have got water in my plugs cuz when i started to drive it , my car started bogging out making me lose power in every gear. by the time i got home i was doing like 15mph at 6000rpm in 1st just to make it home. when i started checking the car i noticed my cat was glowing red. i let it cool and took it off. i hallowed it out with a pipe and hammer. put it back on. dried my plugs and it drove again. ran like crap till the water worked its way out. fucked my whole weekend up. now i smell more exhaust and when i punch it i fart out a big puff of black smoke. i live in texas so the emission laws are sweet. no sniffer to pass inspection. **** as a matter of fact i got my stickers from some half *** shop that didnt even check my car. the cat looks stock but its not. i wonder if i lost power by this?</TD></TR></TABLE>
i pretty sure u lost power .
but like this other cat said check ur fuel mix, see why and how ur cat got clooged , unless its was over 5 yrs might be time for a new one
pbink
Aug 28, 2005 11:50 AM
hYpE-R-29
Aug 21, 2003 09:07 AM
disturbd696
35
Jun 4, 2003 12:04 PM
