plz help how do i put a 89 civic hatch cluster into an 89 crx
This may take some time and effort but if you look at the rear of your CRX cluster and follow the copper colored lines from where the plug enters to where they end you can then determine what color wire goes where. Any line that ends at a solder is taken under other lines and should contine on from another solder point to it's destination. Some of these will go to multiple points, usually a ground or to multiple back lights. Compare this to the Civic cluster and you should be able to swap wires around. IF you have access to the Civic cluster plugs, just compare wrie locations and swap.
Just bumped a thread started by exsinnovation, check the information there!
Dan
Modified by wood 1 at 8:50 AM 5/25/2006
Dan
crex23
May 17, 2009 04:06 PM
sothasom9
Sep 5, 2008 10:57 PM
