Which way to install check valve????
Old May 25, 2006 | 04:16 AM
92hatchattack's Avatar
Default Which way to install check valve????
Simple question guys, i took my check valve for the breaks off my d series, and now i do know which way to install it. How can i tell which way it needs to go??? Common sence tells me it could be a dangerous situation if installed properly no???
Old May 25, 2006 | 08:13 AM
JimBlake's Avatar
Default Re: Which way to install check valve???? (92hatchattack)
The arrow should point away from the brake booster. Towards the intake manifold.
You can verify the valve is OK by using a MityVac or blowing thru it. It's only supposed to flow in the direction of the arrow.
Old May 25, 2006 | 07:23 PM
thank you!!!
em1 Ziggy
Apr 17, 2006 04:08 AM
spidermancivic
Jun 16, 2004 09:13 AM
MooreBoost
Jan 17, 2003 03:21 PM
