Code 9 HELP!
Old Apr 13, 2002 | 08:08 AM
civicboisi's Avatar
Default Code 9 HELP!
Im getting code 9 from my ecu. Says its the TDC sensor or Crank angle sensor. How do i go about fixing it??? 89 Si motor in 90 civic hatch.
Old Apr 13, 2002 | 08:16 AM
CRexDX's Avatar
Default Re: Code 9 HELP! (civicboisi)
i have a code 9 also, the site i looked at said it was cylinder position sensor(CYP). i took my dist cap off, and the sensor was in quite a few pieces.
Old Apr 13, 2002 | 08:18 AM
wronghand's Avatar
Is it a new install? If so check you wiring on the distributor.
Old Apr 13, 2002 | 09:31 AM
civicboisi's Avatar
Default Re: Code 9 HELP! (wronghand)
i know its not my wiring...i'll check the distributor...thanks guys
TyeJ23
Nov 7, 2005 01:42 PM
Civic Racer X 7
Aug 4, 2003 10:50 AM
