Cutting Fairings
Old May 24, 2006 | 08:39 PM
mbpowner's Avatar
Default Cutting Fairings
Hey
I made a thread a while ago about which frame sliders I should get. Well i got some frame sliders that require a hole being cut. Anyone have suggestions on what I should use or a procedure I should use for the left side(side where clutch is)?
Should I cut from the front going through or from the back to front? I need to cut a hole at least 2 inches around so should I use a dremel or a different tool?
I appreciate anyones comments and feedback. Thanks
Old May 24, 2006 | 08:44 PM
marmaladedad's Avatar
http://www.zmoe.com/sliders.html
Quick and dirty:
1. Use a powerdrill and a hole saw.
2. Cut from outside to inside.
3. Use the dremel to clean up the rough edges.
The PlayDoh method worked great for me. Added bonus - you can snack on the playdoh while working!
Old May 24, 2006 | 08:46 PM
EGlovr's Avatar
http://www.inturace.com/Tutorial/FS1.htm
Old May 24, 2006 | 08:47 PM
What the....yours has the bigger pictures.... me
Old May 24, 2006 | 08:48 PM
EGlovr's Avatar
lol. but you were first.
now that i look at it, the pics are exactly the same.
Old May 24, 2006 | 09:03 PM
mbpowner's Avatar
Default Re: (EGlovr)
awesome, i didnt think of the playdo stuff, good idea . I was going to go from inside out so im glad i didnt. I will have to do this tommorrow for sure
edit: thanks to the both of you
Old May 24, 2006 | 09:15 PM
Good luck! Remember, measure twice, cut once.
LifeMage
Feb 4, 2008 11:00 PM
640K Crew
Jan 28, 2006 08:43 PM
00b18b
Oct 5, 2001 05:13 PM
