Will dc jdm 4-1 header fit with stock crossmember??
Searched to no avail. I know most 2.5 collector headers such as profab, rmf etc require aftermarket crossmember, does the dc?? This is an ls/vtec..
Modified by tygsr at 6:38 PM 5/24/2006
If it's a b16 you will have to cut a the front crossmember a bit so it will fit.I had to do it on my 91 crx.If the motor is already in it's a bitch to get that header on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by category5 SI »</TD></TR><TR><TD CLASS="quote">If it's a b16 you will have to cut a the front crossmember a bit so it will fit.I had to do it on my 91 crx.If the motor is already in it's a bitch to get that header on. </TD></TR></TABLE>
HOw bout an ls block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tygsr »</TD></TR><TR><TD CLASS="quote">
HOw bout an ls block?</TD></TR></TABLE>
Same thing. I would suggest going with an aftermarket crossmember so you wouldnt have to hack anything.
the header attaches to the head not the block...
just put the car on jack stands....drop front xmember...fit header...see how much you gotta bang in the xmember...bang it in...try n fit again...if it needs more room, keep bangin it till it clears...its not hard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">
just put the car on jack stands....drop front xmember...fit header...see how much you gotta bang in the xmember...bang it in...try n fit again...if it needs more room, keep bangin it till it clears...its not hard</TD></TR></TABLE>
Well no kiddin
Well no kiddin
Well no kiddin
why did you make this thread again?
Well no kiddin
</TD></TR></TABLE>why did you make this thread again?
why did you make this thread again?</TD></TR></TABLE>
To see if anyone had experience of it fitting without having to hammer the hell out of it..
And when I said ls block I meant long block. There may have been some confusion there...
And when I said ls block I meant long block. There may have been some confusion there...</TD></TR></TABLE>
Just get out your plasma cutter, notch it out, and fab up a nice plate to finish it back off, so it looks nice and custom, or buy aZ-10 like I did. BTW I got a Real OEM Honda JDM 4-1 header for sale, if interested.
specie
Nov 2, 2006 07:26 AM
