no spark question
i know this has probably been asked a million times before but i searched and came up with 939 f/s threads....
my car has no spark what else is there to check besides grounds and the wiring
-coil
-igniter
the car crankes but no spark
-coil
-igniter
d15b vtec wired obd1 with a p05 ecu converted to vtec with p08 maps...
but that shouldint make a difference it should all basicaly be the same no?
yea it was running fine just broke down on me
i just got back from testing the coil there is a little more resistance than thre is suppose to be but idk if its "fried"
suppose to be between 9.7-14.6 and i got 16.89
and primairy suppose to be .63-.77 an i got a fluxuation between .7 and .8
keep in mind this is also an obd1 dizzy and coil and i only had the test sheet for an obd0 dizzy and coil do idk if it makes a difference i just made a new thread about it
Here is the service manual page for the coil in an obd1 distributor.
According to the manual your coil tests out fine. Try a new ignitor.
http://members.shaw.ca/jeremydde/coil.pdf
rex_89 !!
Mar 15, 2011 12:06 AM
spiceisler
Jul 30, 2005 01:11 AM
