starter bolt sizes
Old May 24, 2006 | 04:32 PM
si0385.'s Avatar
Default starter bolt sizes
what size is the starter bolt that goes in the bottom of the starter... i think its bigger than the top one i know its longer...
does anyone know the exact size?
Old May 24, 2006 | 05:43 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: starter bolt sizes (si0385.)
It helps to state what you are working on..
Old May 24, 2006 | 06:39 PM
si0385.'s Avatar
Default Re: starter bolt sizes (88DXCRX)
my bad its an a6
Old May 24, 2006 | 07:44 PM
88DXCRX's Avatar
The longer bolt size is 10mm x 1.25mm pitch x 110mm= total length of bolt
[actual fastening area=100mm]
The shorter bolt size is 10mm x 1.25mm pitch x 45mm= total length of bolt
[actual fastening area=35mm]
{The head size of the bolt is a 14mm.}
Old May 25, 2006 | 01:34 AM
si0385.'s Avatar
your the man
Old Nov 18, 2015 | 05:16 AM
McArthur Square's Avatar
I have a 96 Honda Accord coupe. Are my bolts supposed to be different lenghts too? If so where does the shorter bolt go, the left or right side of the starter?
Old Nov 18, 2015 | 05:22 AM
BLU CIVIC's Avatar
Track Advocate
Not sure if they're all configured the same, but the short bolt went on top and the longer bolt went on the bottom of my B series
Old Dec 12, 2016 | 03:23 PM
JustDrive's Avatar
Its common design on both alternator and starter to have two diff sizes. Would those sizes be the same on a d16z6?
DC2 to AP2
Acura TL, RL & ZDX
Nov 19, 2005 06:37 PM
SGR Teg
Jan 29, 2003 06:53 AM
