How do I attach the rear cargo area gate/door?
Old May 24, 2006 | 02:19 PM
RPM_69's Avatar
Default How do I attach the rear cargo area gate/door?
How am I supposed to mount the rear cargo hatch door (the vertical door between the passenger and cargo compartments). Check the pic below. I can't find anything in the shop maunual or online that helps. I suspect I am missing some part(s). Please post a pic/diagram of how this thing is supposed to be attached.
THANX!
Old May 24, 2006 | 02:34 PM
RCautoworks's Avatar
Default Re: How do I attach the rear cargo area gate/door? (RPM_69)
Should be some plastic pieces down below.
Old May 24, 2006 | 03:07 PM
Tyson's Avatar
Default Re: How do I attach the rear cargo area gate/door? (90blackcrx)
i cant remember if theres anything specifically missing or not, but from what i remember you just needed 4 of those black screws and screwed it down into white plastic grommets that were plugged into the chassis (they lock into square holes).
the round plastic pieces (that i dont see and may be what 90black is talking about) are to keep the carpet fitted properly, not particularly necessary but nice to have.
Old May 24, 2006 | 03:29 PM
Default Re: How do I attach the rear cargo area gate/door? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
the round plastic pieces (that i dont see and may be what 90black is talking about) are to keep the carpet fitted properly, not particularly necessary but nice to have.</TD></TR></TABLE>
Yep
Old May 24, 2006 | 06:39 PM
RPM_69's Avatar
Any pics of this thing bolted in? I still can't figure out what angle or which way to flip the metal hinge.
Thanx
Old May 24, 2006 | 06:41 PM
It can only go on two ways really
Old May 24, 2006 | 07:36 PM
GMR*Spork's Avatar
the metal hinges are supposed to be folded back into the cargo section of the car, there should be a few white plastic rectangular grommets to line the holes up with...
maybe I'll go take a pic of mine.
EDIT
mount the divider with the brackets facing back
flip the carpet forward over the divider to reveal the brackets and screw the brackets into the white plastic anchors in the floor
should have rotated these 90degrees, but i think you get the idea
d/s mount location:
p/s mount:
...please excuse how disgustingly filthy my cargo area is, it should be cleaned and shined up this week(end)
Modified by SporkHSP at 10:48 PM 5/24/2006
Old May 24, 2006 | 11:12 PM
RPM_69's Avatar
Default Re: How do I attach the rear cargo area gate/door? (SporkHSP)
SWEET - exactly what I needed. H-T members rock!
t_ank
Mar 28, 2010 06:51 PM
biggjerryc
Apr 4, 2008 04:19 PM
Naruto
Jan 17, 2008 02:37 PM
E.Honda
May 29, 2007 06:15 PM
CivicWagon
Nov 9, 2004 05:37 PM
