GSR into EF Hatch & I want to keep A/C!!!!!!
Old May 24, 2006 | 12:52 PM
TurboJdmEF9's Avatar
Default GSR into EF Hatch & I want to keep A/C!!!!!!
I AM PUTTING MY GSR BLOCKED JDM B16A1 HEADED SWAP INTO MY EF HATCH AND WANTED TO KNOW HOW I COULD KEEP A/C LMK WITH ANY SUGGESTIONS OR WRITE UPS LMK ASAP THANKS ALOT GUYS, JOHN
Old May 24, 2006 | 12:53 PM
temp's Avatar
Default Re: GSR into EF Hatch & I want to keep A/C!!!!!! (TurboJdmEF9)
then buy the bracket, problem solved
Old May 24, 2006 | 12:54 PM
ludesrv's Avatar
Default Re: GSR into EF Hatch & I want to keep A/C!!!!!! (temp)
He's right. Go to honda and pick up the B series AC bracket. Have fun getting a belt on without bashing your frame. We bash the frame just for the stock crank to go in.
WHAT BRACKET AND WHERE CAN I BUY IT LMK GUYS
Old May 24, 2006 | 12:55 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboJdmEF9 &raquo;</TD></TR><TR><TD CLASS="quote">WHAT BRACKET AND WHERE CAN I BUY IT LMK GUYS</TD></TR></TABLE>
lets see, you want to put A/C in your car, so i think we are talking about the exhaust hanger bracket
Old May 24, 2006 | 12:56 PM
temp's Avatar
Default Re: GSR into EF Hatch & I want to keep A/C!!!!!! (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote"> He's right. Go to honda and pick up the B series AC bracket. Have fun getting a belt on without bashing your frame. We bash the frame just for the stock crank to go in.</TD></TR></TABLE>
IIRC i know the name of a company that makes a custom bracket
Old May 24, 2006 | 12:58 PM
HOW MUCH DO YOU THINK IT'LL BE AND HOW HARD IS THE CHANGE
Old May 24, 2006 | 12:59 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboJdmEF9 &raquo;</TD></TR><TR><TD CLASS="quote">HOW MUCH DO YOU THINK IT'LL BE AND HOW HARD IS THE CHANGE</TD></TR></TABLE>
http://www.yellowpages.com
look up a dealer and make a phone call. and no.
Old May 24, 2006 | 02:03 PM
Ass$nyper's Avatar
Pirate General...YARRRR
order a bracket and get ready for a beating fest I had a gsr with a/c and a header.
now a lsvtec header and a/c
Old May 24, 2006 | 02:47 PM
IwantaGlock18's Avatar
I think the 94 Delsol VTEC bracket works, but I have no first hand experence with it.
Old May 24, 2006 | 03:02 PM
HT Chaplain's Avatar
Loved
Default Re: (IwantaGlock18)
http://www.jdmshit.com/hcp/index.html
hcp ac bracket i used it and it works perfect
Old May 24, 2006 | 03:34 PM
temp's Avatar
Default Re: (HT Chaplin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin &raquo;</TD></TR><TR><TD CLASS="quote">http://www.jdmshit.com/hcp/index.html
hcp ac bracket i used it and it works perfect</TD></TR></TABLE>
i wanted him to search for this
Old May 24, 2006 | 03:52 PM
Wes V's Avatar
Default Re: (temp)
The "jdmshit" bracket looks like the one originally sold by Place Racing. Hopefully it's of better quality, because I purchased one of the Place ones and it was worthless.
The bracket kit to buy is the one made by Hasport. It will allow you to use either of the two different compressors that were used by honda during the EF days. I've got one of the brackets on my GSR motored 89 hatchback.
The rumor of the Del Sol bracket working isn't totally true (and may not be true at all). I believe it's called marked as P54. I know for a fact that it will NOT work with the sanden compressor!
Just shell out the money and get the Hasport "EFAC" kit!
And by the way, please turn off the capital letters!!!
Wes V
Old May 24, 2006 | 04:00 PM
temp's Avatar
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">The "jdmshit" bracket looks like the one originally sold by Place Racing. Hopefully it's of better quality, because I purchased one of the Place ones and it was worthless.
Wes V</TD></TR></TABLE>
i never had a problem with HCP quality
Old May 24, 2006 | 05:52 PM
Loved
Default Re: (temp)
hcp has just as much of a good reputation as hasport! I used it and can verify it is top quality. it let you use all the stock ef ac components and mounts in the original ef location
Old May 24, 2006 | 06:21 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin &raquo;</TD></TR><TR><TD CLASS="quote">hcp has just as much of a good reputation as hasport! I used it and can verify it is top quality. it let you use all the stock ef ac components and mounts in the original ef location</TD></TR></TABLE>
Old May 24, 2006 | 06:25 PM
.Thomas's Avatar
Default Re: (temp)
caps lock .... unessary
Old May 24, 2006 | 09:56 PM
antnyc9r1x's Avatar
Link to another post. I used Hasport bracket. That fit great. Pic is my 91CRX DX with B18C1 swap.
https://honda-tech.com/zerothread?id=1629002
Old May 24, 2006 | 11:25 PM
synergy10's Avatar
Default Re: GSR into EF Hatch & I want to keep A/C!!!!!! (antnyc9r1x)
PM'ed you antnyc9r1x
Old May 24, 2006 | 11:41 PM
bks84's Avatar
Loved
you can also order the bracket from a 97 CRV... P7J is the part number its cheaper than the del sol vtec bracket.
Old May 25, 2006 | 04:53 AM
temp's Avatar
Default Re: (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">you can also order the bracket from a 97 CRV... P7J is the part number its cheaper than the del sol vtec bracket.</TD></TR></TABLE>
show proof of fittment
Old May 25, 2006 | 05:00 AM
bks84's Avatar
Loved
Default Re: (temp)
its the same bracket, a guy here local is using it. you want proof, go buy it. or... in the famous words of HT SEARCH...
i searched for p7j and it came back with 6 results of WTB's where people are asking for either the p54 or the p7j... i think thats proof enough
Old May 25, 2006 | 05:07 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">its the same bracket, a guy here local is using it. you want proof, go buy it. or... in the famous words of HT SEARCH...
i searched for p7j and it came back with 6 results of WTB's where people are asking for either the p54 or the p7j... i think thats proof enough</TD></TR></TABLE>
i dont, all that says is that people with b20's want an A/C bracket.
Old May 25, 2006 | 01:49 PM
Wes V's Avatar
Default Re: (temp)
I'll say it again; the P54 (del sol) will not work with the EF vintage sanden compressor!
I found a dealer that happened to have one in stock and drove 50 miles to look at it. I brought my Sanden with me and I can say that it will NOT bolt on!!!! I confirmed that it was a P54 by the number cast into it.
Now I can't say if it would work with the other compressor used during the EF years.
It's possible that people that do use that bracket also use the matching compressor. The problem with that is that the hose fittings are different and getting the del sol hoses to fit is questionable.
Wes
Mekk82
Apr 17, 2013 11:32 AM
triangle1020
Jul 30, 2009 06:47 PM
HondaFerris
Mar 2, 2007 10:35 AM
budomove
Feb 8, 2007 01:40 PM
on2wheels
10
Dec 8, 2005 01:15 PM
