Which sway bar are the best
suspension techniques is pretty common.
although, id be interested in seeing a tanabe rear swaybar.
you only need a rear bar anyway. dont get a new front one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">suspension techniques is pretty common.
you only need a rear bar anyway. dont get a new front one.</TD></TR></TABLE>
What exhausts will the ST fit with though?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">
What exhausts will the ST fit with though?</TD></TR></TABLE>
it does have fitment issues with large exhausts. but its manageable from everything ive seen.
oh, and i guess the BEST is a mugen rear sway bar. fits like stock. i have one
</TD></TR></TABLE>how much did that set you back
First thing I do anymore, is put an ST bar, on every EF I buy. Great mod. Never seen the Mugen one, but probally because you have to fly to Japan to find one.
actually, sold my jackson racing rear swaybar (pretty much same as ST) and made up for the mugen bar. was used, posted here on HT for sale and was first to swoop in and buy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">actually, sold my jackson racing rear swaybar (pretty much same as ST) and made up for the mugen bar. was used, posted here on HT for sale and was first to swoop in and buy. </TD></TR></TABLE>
Sweet is it adjustable? Do you have any pics? It sounds intrigueing although a deal like that will probally never come around.
<--- Has no rear sway bar and freaks DrDisco69 (Mike) out everytime we go out on track and I start tossing the car around.
Guess I will need to invest into a sway bar for the CRX.
Interesting Mugen rear sway bar....I was think about getting a big 32mm solid front bar for the CRX.
not adjustable. those adjustments at the end of the ST bar are pretty worthless actually. if you do the math, its not changing it more than 5% if i recall correctly.
just imagine a 22mm stock bar. thats pretty much what it is.
I rock 0 sways
Myself for what i've been wanting ST seems to be best for all around and bang for buck.
I'm sure mugens are great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">does it have toaly rad mooooogen emblems!?!?!?!?!?
Only for you temp, only for you
</TD></TR></TABLE>Only for you temp, only for you
from what i see, the ST rear swaybar made for the DA integra is a direct fit for them. some pl have fit DA integra rear swaybars on their EF chassis. that is an option for better fitment. however, its 19mm, not 22mm. still better than stock 14.4mm.
if it did, itd be blocked by the stock exhaust i rock...
</TD></TR></TABLE>if it did, itd be blocked by the stock exhaust i rock...
if it did, itd be blocked by the stock exhaust i rock...</TD></TR></TABLE>
hmmm, not like doubting you bro. just a question, how are you sure its a real mugen bar?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">not adjustable. those adjustments at the end of the ST bar are pretty worthless actually. if you do the math, its not changing it more than 5% if i recall correctly.
just imagine a 22mm stock bar. thats pretty much what it is.</TD></TR></TABLE>
That would be sweet it would also clear my Thermal.......
neuspeed rear bar alone costs $333.
looks like it comes with brackets to fit like later models on the subframe. i personally dont like mounting the swaybar like that.
http://store.summitracing.com/...w=sku
looks like it comes with brackets to fit like later models on the subframe. i personally dont like mounting the swaybar like that. http://store.summitracing.com/...w=sku
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">I use stock 2g teg bars front and back can't beat that for $12 each from the junk yard</TD></TR></TABLE>
Yeah but you also have and Si. Which is great cause you can do exactly what you did. However I would have found a HF front sway instead. People owning the lower model CRXs have to get something "like" ST to add to the car so they can even have rear sway.
I would have to think the Beefy 1/4" think ST mounts are better than the chincy stock mounts though. Do all of the others come with new mount brackets? I dunno I like my STs, but I'm open for options, I gotta get one for my CRX soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart »</TD></TR><TR><TD CLASS="quote">
That would be sweet it would also clear my Thermal.......</TD></TR></TABLE>
It clears my Thermal (classic) just fine. But if you need just a tad bit more clearance, you can add a spacer bar between the ST mount bracket and the chassis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***-assin »</TD></TR><TR><TD CLASS="quote">
HEHE omg omg omg i want like 14 of them
</TD></TR></TABLE>HEHE omg omg omg i want like 14 of them
