6th gen brake conversion
Old Apr 13, 2002 | 12:37 AM
DeViuS's Avatar
Default 6th gen brake conversion
has anybody done a drum to disc rear conversion on 6th gen? what will i need off the ex? besides caliper,rotor,hub,brakelines?... and is it just bolt on?
Old Apr 13, 2002 | 02:58 AM
CmptchAV6's Avatar
Default Re: 6th gen brake conversion (DeViuS)
if I were you get the stuff off the V6 accord. Much bigger roters and calipers on that setup.
Old Apr 13, 2002 | 08:42 AM
benzcivic99's Avatar
Default Re: 6th gen brake conversion (CmptchAV6)
Would the ABS system be a problem if you were to put the V6 brakes on a DX (without ABS)?
Old Apr 13, 2002 | 07:05 PM
CmptchAV6's Avatar
Default Re: 6th gen brake conversion (benzcivic99)
Well from my understanding you wouldnt use the V6 accords ABS system unles you did all the extra work to add its systems in. As far as the change you would take he calipers rotors and all other nesassary pieces and change them out with the stuff on the rear. I would do the front as well since the V6 has much bigger rotors, well that is if you dont just get an aftermarket kit from brembo or something like that.
Carter Coffie
Jun 10, 2019 12:26 PM
jdmstyleEJ6
Feb 18, 2012 02:40 AM
Bluecivicjoe
Suspension & Brakes
Feb 19, 2010 05:28 AM
Irishweird00
Jul 14, 2009 02:30 PM
kit50si
13
Nov 18, 2006 06:06 AM
