Cutting Flex Bellows?
Old May 24, 2006 | 10:58 AM
scartail's Avatar
Default Cutting Flex Bellows?
Hey guys...
I've got a 8" flex bellows laying around that I want to cut in half. Is this ok to do? Has any of you done this? Basically, my plan is to use hose clamps on both side to make sure the wire weave doesn't fray. Then use some piping (a large pipe (cover the weave) to weld the cut ends to. Maybe have to weld a large pipe to cover the weave. What do you guys think?
Thanks.
Old May 29, 2006 | 02:46 PM
RC000E's Avatar
Default Re: Cutting Flex Bellows? (scartail)
Why......?
You want to cut a piece of braided flexpipe and cover it in a bigger pipe?
Old May 31, 2006 | 10:22 AM
scartail's Avatar
Default Re: Cutting Flex Bellows? (RC000E)
It's a left over part, that I want to use, but don't have space for the whole 8".
I want to cut the the braided portion (basically, cutting it in half), and see if I can put something back on.
Old Jun 2, 2006 | 02:15 PM
RC000E's Avatar
I see.....well give it a shot and take pics....best you can do there.
Old Jun 2, 2006 | 09:47 PM
Eddiebx's Avatar
maybe it might be gbetter if u wrap tape aroudn the braided lines and then cut it, mabye less fraying?
Old Jun 5, 2006 | 04:08 PM
scartail's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">maybe it might be gbetter if u wrap tape aroudn the braided lines and then cut it, mabye less fraying?</TD></TR></TABLE>
Yeah, I was planning on using a big hose/coupler clamp. Let me look at it more closely.
Old Jun 5, 2006 | 04:37 PM
2point2's Avatar
use a chop saw.. maybe wrap it in tape? a bandsaw might be dangerous if you're doing it by hand.
edit: the chop saw might be dangerous too.. just make sure you have that thing clamp down good because saws love to grab the braids.
TVT_DESIGN
Welding / Fabrication
Apr 11, 2008 07:31 PM
EdsGTI
100
Feb 26, 2007 01:38 PM
Superorb
16
Feb 23, 2006 06:18 PM
BlueShadow
Jun 11, 2005 09:32 PM
hondaapi
Jan 18, 2005 04:33 AM
